VTEC Head Swap onto F22B2
Old Jan 23, 2007 | 11:31 AM
MCHAccordLX's Avatar
Default VTEC Swap F22B
Hey everyone, I'm wondering about putting VTEC on a F22B engine in a 1996 Accord LX. Is this possible? The car has OBD 2 and is a 2.2L 4 Cyl. with a SOHC. I'm sorry if someone has already posted about this, and if they have, if you could just direct me that would be grand.
Anyways, I want to put VTEC on my engine, what all is involved. I would do the work myself, but don't really know too much about engines. I'm fairly good with the electronics and stuff, but I'm going to need some advice on the mechanics. What all makes the engine a VTEC? What parts will I buy when I do this project? Is there some step by step guide somewhere that I can follow or anybody that has done this swap before?
I figured, if I did it, I would do it this summer when I planned to change the Timing Belt, so I could just switch it over to the chain. What do you all think? Like I said I'm looking for advice, so if it sounds like I don't know what I'm doing, set me straight... If you don't mind. Thanks for the help everyone!
Old Jan 23, 2007 | 11:35 AM
SuperSlow's Avatar
Default Re: VTEC Swap F22B (MCHAccordLX)
chain?
lots of searching to be done on your part... set yourself straight.
Old Jan 23, 2007 | 11:37 AM
porc933's Avatar
I thnk you should go w/ the h22 swap. If you go to this thread half way down the page will explain everything to u. Good luck!
https://honda-tech.com/zerothread/797528
Old Jan 23, 2007 | 11:38 AM
SuperSlow's Avatar
Default Re: (porc933)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porc933 &raquo;</TD></TR><TR><TD CLASS="quote">I thnk you should go w/ the h22 swap. If you go to this thread half way down the page will explain everything to u. Good luck!
https://honda-tech.com/zerothread/797528</TD></TR></TABLE>
The difference in cost between what OP wants and what you recommend is substantial.
Maybe he should go with an LS1 swap instead. I think that would be cool. And AWD.
Old Jan 23, 2007 | 12:36 PM
porc933's Avatar
all i was trying to do is make a suggestion he doesn't have to listen to me but a least i gave him some kind of insight as to what to do.
Old Jan 23, 2007 | 02:54 PM
TouringAccord's Avatar
H-T Order of Merit
Go to the Accord FAQ and look in the Swaps section. There is a link in there for a F22B1 head swap. Click on that and read up. I believe it was done on a F22Ax engine but the required parts and setps taken are pretty much the same.
Also, you can't put a timing chain on this engine, you have to stick with the belt.
And just a FYI, you motor isn't ecatly a F22B, it's a F22B2. I know, not a big difference right, well there is a F22B motor (which is DOHC) and it can get confusing when people don't list their engine correctly or fully. The VTEC engine of that year was the F22B1 and thats the engine you want to get parts from.
You asked what makes an engine VTEC... read this...
http://auto.howstuffworks.com/question229.htm
there are a couple more links at the end of the article as well. That should give you a good understanding of VTEC.
Old Jan 23, 2007 | 05:59 PM
Default Re: VTEC Swap F22B (TouringAccord)
Hey thanks for the responses everyone. Yeah I wasn't sure if that 2 on the end of F22B2 was important. Now I know. I thought VTEC was a chain? Isn't that how they do the variable timing? That's how it is on my Dad's Nissan with (Nissan's version of the VTEC). Whatever though. Thanks for the help I really do apprecaite it!
I would swap the H22 in there except, it's an automatic, so it's really not worth putting THAT much effort into it. Just the basic maitenece and some extras. HAHA!
Could I really go AWD on my Accord? That would be compltely awesome!
Old Jan 23, 2007 | 06:24 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MCHAccordLX &raquo;</TD></TR><TR><TD CLASS="quote">I thought VTEC was a chain? Isn't that how they do the variable timing?</TD></TR></TABLE>
Did you read that link I posted above? That explains what VTEC is and how it works.
Old Jan 23, 2007 | 06:28 PM
Bboy_Trevstuh817's Avatar
Go with a h23 head swap you won't be sorry!
Old Jan 23, 2007 | 06:50 PM
mnizzy's Avatar
Default Re: (Bboy_Trevstuh817)
Ive been thinking of doing an h22 swap into my '92 Accord LX in Eagan. Not sure what im gonna do with it though. Just thought id throw that out there, good to see honda lovers in the burbs.
Old Jan 24, 2007 | 05:57 AM
Default Re: (mnizzy)
Yeah I looked into all those links, pretty helpful stuff. That link that had a step by step was pretty useful, although it would have helped to have some pictures, haha. It doesn't sound all that complicated, I just gotta make sure I'm clean about it, and have a service manual.
mnizzy, you live in Eagan? That's awesome!
Old Feb 22, 2007 | 03:27 PM
Alright, I got the go ahead this summer me and my father are going to swap it in there. I just don't know where I'm going to get the parts and such. How much should I expect to pay for all this? Don't want to get a bad deal here, yet I don't want crap parts.
Old Feb 22, 2007 | 04:56 PM
Twixle's Avatar
ate my pixel
Depends what kind of parts you use. If you're just going to take the stock head, vtec sensors, and ECU out of a junker accord, you could probably get out of it for a few hundred bucks.
Old Feb 23, 2007 | 10:53 AM
Default Re: VTEC Swap F22B (accord2021)
Yeah I was hoping to get most of the parts from either a u pull or a junkyard.
Old Feb 24, 2007 | 03:38 PM
Default Re: VTEC Swap F22B (Mr Wonderfull)
Would it contain everything I need to do this swap? I may be interested. What year and model is it from and why are you getting rid of it?
What is a tps? (sorry noob question)
Old Feb 24, 2007 | 06:41 PM
Slomies's Avatar
I have most of / if not all of the parts to do the swap. I would just have to pull them out of storage if you're really interested since I had to pack up everything a few month ago when I moved out.
Old Feb 24, 2007 | 08:02 PM
TreWatts's Avatar
Default d
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bboy_Trevstuh817 &raquo;</TD></TR><TR><TD CLASS="quote">Go with a h23 head swap you won't be sorry!</TD></TR></TABLE>
bunk that
h22 head swap ftw!!!
Old Feb 25, 2007 | 06:35 AM
H-T Order of Merit
This is not a for sale thread.
If you want to sell your stuff, use the PM feature.
Old Feb 28, 2007 | 08:53 PM
turbo_f22b2accord's Avatar
hey I might be interested in that setup,i have a f22b2 and i want to turbo it
Dre_miller
Aug 4, 2016 08:43 AM
beaver95
Apr 13, 2012 08:18 PM
StJimmy037
Oct 12, 2007 05:50 AM
hotinteggy
Aug 4, 2007 02:32 PM
omarisramo
Jul 29, 2007 09:09 PM
