headers?
Old Jan 23, 2007 | 10:41 AM
hondc5's Avatar
Default headers?
hey guys i have dc sports race headers in my dc5 but they were hiting the bottom off my car so i put the energy suspension inserts but the the car shakes like crazy so i wanna change the headers for dc5 type-r headers i have intake exhaust, and k-pro will i loose to much by changing the headers i need some feedback before i do this or anyother way to stop the car for shaking
Old Jan 23, 2007 | 11:50 AM
DC5StylZ's Avatar
Default Re: headers? (hondc5)
put ur car back to stock hight and u wont need to get rid of the raceheader......most of the power u make if from the raceheader so ull feel a big loss in power..
Old Jan 23, 2007 | 12:50 PM
inkong's Avatar
Default Re: headers? (DC5StylZ)
how low are you to the ground right now anyways?
Old Jan 23, 2007 | 01:18 PM
hondc5's Avatar
Default Re: headers? (inkong)
my car is drop 2 in but i dont think is hittni cause is to low do i think is generating to much power and is pulli the engine back alot specially down shifting
Old Jan 23, 2007 | 02:08 PM
Schwebel's Avatar
The shaking you feel is from the ESMM's. If it's really bad you might have a broken motor mount. Are you sure you got the right header for your car? I believe the DC5-S and the non-S use two different lengthed headers. Someone correct me if I'm wrong. I say jack you car up and visually inspect the mounts while its running and check out whats happening when you rev your engine. And yes you will lose power if you put a cat back on your car.
Old Jan 24, 2007 | 07:20 AM
DC5StylZ's Avatar
Default Re: headers? (Schwebel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schwebel &raquo;</TD></TR><TR><TD CLASS="quote"> The shaking you feel is from the ESMM's. If it's really bad you might have a broken motor mount. Are you sure you got the right header for your car? I believe the DC5-S and the non-S use two different lengthed headers. Someone correct me if I'm wrong. I say jack you car up and visually inspect the mounts while its running and check out whats happening when you rev your engine. And yes you will lose power if you put a cat back on your car. </TD></TR></TABLE>
he is correct the s and non s are dif
Old Jan 24, 2007 | 09:29 AM
hondc5's Avatar
i did got the rigth headers and i dont have a broken mount because i went to the dealer and my home chek out for me and is fine but the proble is when im stop and specially when the a/c is on
Old Jan 24, 2007 | 12:23 PM
jared234's Avatar
Did putting the race header on throw a check engine light.
Also, has anyone heard of Megan. Do they make a good header.
Old Jan 25, 2007 | 02:34 PM
JDM.K20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondc5 &raquo;</TD></TR><TR><TD CLASS="quote">i did got the rigth headers and i dont have a broken mount because i went to the dealer and my home chek out for me and is fine but the proble is when im stop and specially when the a/c is on</TD></TR></TABLE>
Thats supposed to happen with the esmm's, thers nothing wrong with you mounts, header, or ride height. They vibrate the most when your stopped and have your a/c on at any time but after they begin to break in they get alot quiter and less annoying. Just give it a little time . If its just too much to handle, you can just get Innovative Motor Mounts for around $220 or so and they will do even a better job than the esmm's just without causing your car to shake and be annoying.
Old Jan 25, 2007 | 07:51 PM
whiteDCfiver's Avatar
Default Re: headers? (jared234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jared234 &raquo;</TD></TR><TR><TD CLASS="quote">Did putting the race header on throw a check engine light.
Also, has anyone heard of Megan. Do they make a good header.</TD></TR></TABLE>
Ya you will throw a cel code cause of the o2 sensor on the cat.
Megan is a great company that makes great products...for the price.
jxhxb
Dec 1, 2008 09:19 PM
mkiv98
Feb 13, 2005 01:45 AM
integGSR805
Dec 20, 2004 03:59 PM
The new guy
Dec 1, 2002 02:17 PM
