Mid-Atlantic (Sales) VA, DC, and MD
fs/ft 91 da b16 turbo 340+whp
Old Jan 23, 2007 | 10:23 AM
lambertincorp's Avatar
Default fs/ft 91 da b16 turbo 340+whp
1991 Honda/Acura Integra
13.10@ 110mph ¼ Mile Time with Nitto 555R Drag Radials at 12.5psi
292whp and 202wtq @ 12.5psi boost pump gas
Car is now tuned for 19lbs making 350+whp and 230+wtq
7500obo
Interior
-Kenwood Flip-Face Head Unit
-Sony Explode Front Speakers (6.5")
-Sony Explode Rear Deck Speakers (6.5")
-Audio-Bahn A-Series Amplifier
-Kicker Competition Solo-Baric 8" Sub with Kicker Matching Box
-Monster Cable 4-Way RCA's
-Authentic JDM Broadway Mirror
-Crime-Stopper 2004 Alarm System
-Auto-Meter Phantom Series Electronic ½ Sweep Fuel Pressure Gauge
-Auto-Meter Phantom Series Electronic ½ Sweep Oil Pressure Gauge
-Auto-Meter Phantom Series Mechanic Full Sweep Boost Gauge
-Blitz FATT 3 Turbo Timer
-JDM GIGA Air Fresheners
Engine
-JDM B16A DOHC VTEC Engine
-JDM YS1 LSD Transmission
-Lexus GS400 COP Igniters
-Hondata Intake Manifold Gasket
-SIR Single Plenum Intake Manifold
-Competition Clutch Stage 4 Sprung Disk and Pressure Plate
-Integra GS-R Flywheel
-Ross Racing 9.0 Compression 81.5mm Bore Pistons
-Eagle Forged Connecting Rods
-Arizona Race and Machine Aluminum Block Guard
-GM 3 Bar Map Sensor
-ACL Racing Engine Bearings (Rods, Mains, Thrust)
-ARP Head Studs
-ARP 2000 Rod Bolts
-Polished Cast Aluminum FMIC w/2.5" Polished End Tanks
-Custom 6 Port Vacuum Manifold
-Custom Catch Can Setup
-Aeromotive Red Anodized Fuel Pressure Regulator 1:1
-Skunk 2 Intake and Exhaust Cam Gears (Red)
-Mildly Polished Throttle Body
-ERL Cast 4 Into1Polished Turbo Manifold
-Turbonetics T3 Super 60 Dual Ball Bearing Turbo
-2.5" Mild Steel 5 Bolt Down Pipe
-Bosch Manual Boost Controller
-Boomslang Fabrications OBD-0 to OBD-2A Conversion Harness
-Custom 2.5" Exhaust (No Cat… No Resonator…)
-Apex I N1 3" Turbo Muffler (Black Chrome)
-AEM EMS Engine Control Management 1050 Box
-Throttle Body Heater Bypass Modification
-Tail 38mm External Dumping Waste-Gate
-HKS SQV Blow Off Valve
-2.5" Turbo Charge Piping
-Precision 880cc Fuel Injectors (Seimens/Decka)
-Walbro 255lph High Pressure In-Tank Fuel Pump
-NGK Spark Plugs (.026 Gap)
-Energy Suspension Front Motor Mount Inserts
-Energy Suspension Drivers Side Motor Mount Inserts
-Energy Suspension Passenger Side Motor Mount Insert
Exterior
-205/55/14 Nitto 555R Drag Radials
-Rota Slipstream 14" Knock Off Wheels
-KYB 4-Way Adjustable Shocks
-Eibach Springs
-Aftermarket 9006-HID Conversion (6000K/Blue)
-JDM PIAA H3 Yellow Fog Light Bulbs
-JDM Amber Bumper Corner and Turn Signal Lights
-Honda Emblems And Badges
-Power Slot Cross Drilled Rotors
-EBC Green Stuff Racing Brake Pads
-JDM Stainless Steel Adjustable Tag Bracket
-DC Sports Front Upper Strut Bar
-Freedom Designs Rear Upper Strut Bar
-Hella Air Horns
-Volk/Rays Racing Aluminum Black Anodized Lightweight Lugnuts
only thing the car need is paint and some better wheels
the car will come with the knock off rotas with a polished lip with nitto drag radials on the front, i just put on a brand new tial wastegate 2 days ago and it has 50 miles on it will consider some trades not sure what so let me know what you got will have pics up within the next couple of days any questions just pm me
Old Jan 23, 2007 | 04:00 PM
Default Re: fs/ft 91 da b16 turbo 340+whp (lambertincorp)
bump
Old Jan 25, 2007 | 08:10 PM
boostedblkef's Avatar
pics?
JDMvirginNC
Mar 6, 2009 08:34 AM
lambertincorp
Jan 23, 2007 03:23 PM
kdawgy2k1
Nov 6, 2006 06:31 PM
M-doc yo!
Apr 9, 2005 08:11 PM
5spdIntegra
Jan 29, 2004 03:58 PM
