90 integra LS - no pedal pressure and its hard to engage into all gears
After I parked, all of a sudden I have no pedal pressure and its hard to engage into all gears. whats wrong? I gotta drive 40 miles back home. can I make it back? help me out guys.
is this the first time it has happened? If its a bad clutch, you may be able to still make it home if this is the first signs of something happening.
it is actually a new clutch. less then a thousand miles on it. 2nd time it has happened. the pedal is sticky, like once you press down on the clutch, it will stay down. only sometimes it will go back up. you think something needs to be tightened?
jesusjdm89
Nov 17, 2010 06:50 PM
GreenMachineRex
May 4, 2004 06:22 AM
