Civic, del Sol, Integra, Prelude parts, universal, ecu, blah blah blah. Help me clean out my damn ga
Seriously, read through the entire list. There’s something for everyone. I think the prices are pretty fair and would like to stay form on them. You can calculate shipping from 55447 and add it to the price or your offer. PM, email, call… 952-200-8208
-James
88-91 civic/crx-
CRX Si rear garnish $5
PM8 CRX Hf ecu $5
PM5 CRX/Civc DX ecu $5
B series into EF mount kit $150
CRX dash clock with pigtail $5
CRX door handle surround – gray $1
Del Sol/EG-
Del sol rear speaker brackets $10
D series non vtec valve cover $10
EG/DC upper A arms $15
EG driver’s side airbags (I have 3) $20 each
EG stock shifter $10
Del sol window switches $15 for the pair
D series starters $10 each
Del sol front speaker cover. Have two, but one is bent from having something set on top of it. $5 for the pair
D16z6 stock cam with gear $10
Top half of D series Chikara torque step header $20
D16Z6 crank pulley $
Del sol rear licence plate panel.. needs paint, partially primered where stickers were sanded off. $50
Del sol front fenders $100 for the pair. One has a small tear inside the wheel well lip that can easily be fixed.
Del sol rear window $50 with motor and big black mounting panel
D16z6 head minus vtec solenoid, includes captive blue valve cover and intake manifold $150 obo
D16z6 block with a bad oil pump and a rod knock $50
d16z6 distributor $50
D series axles, will fit ef, eg, ek without abs. $50
P28 ecu $100. Virgin, but I can include the needed parts to chip it if you need them. Socket, capacitor, blah blah blah.
P06 ecu. Also virgin. $60
D series PS pump. $20
B16 Crane came gears
EK Civic-
OBX axle back for coupe. Came off a friend’s EX. $50
Integra-
PR4 OBD0 LS ecu $25
P75 OBD1 LS ecu $75
2G teg front brake calipers $40 for the pair with brackets
3G Teg LS front brake calipers $40 for the pair with brackets
DC map light $5
2g teg factory option center arm rest $20
Prelude/Accord-
PK2 88-89 prelude Si 5spd ECU $5
F22b1 long block minus intake manifold. Makes some noise, but I haven’t ripped it apart to inspect. May be a rod knock or a bad balance shaft bearing. $100?
F23 intake manifold minus TB. $30
F22 vtec/f23 alternator bracket $10
F22 vtec/f23 AC bracket (aluminum from f23 is much lighter. Drop some weight for….) $10
F23 distributor
F series crank shaft pulley in GREAT shape. $20
Universal-
Blue Honda oil cap $1
Atari Joystick and Pole Position $5
Daytime running light kit (wiring and relays) $10
Synapse missing link for TB mounting $30
2.5 inlet universal muffler.. FART CAN $20
2x 15 inch computer monitors $20 each
Megan Racing 3” turbo muffler $25
17” ADR Ryvers with Nankang tires $350
Two JL audio 12w0 in a sealed box. $125
Legacy 1600w amp. It is a 4 channel amp, can be bridged to two channel, and I believe is 2ohm stable. All channels work perfectly. $75
Darkroom Equipment- $250 obo takes all of it.
-Color photo enlarger that I was using for black and white prints. Has the red.blue.yellow filters built in.
-Old school enlarger timer that I used with above enlarger.
-Two photo printing easels. 8X10 on one side, 2X3, 3X5 and 5X7 on the other side.
-Large darkroom light. About 14X7" lit area. This was enough to cover an entire small darkroom.
-Photo developing tank with two reals. I used this for black and white photo film developing, two at a time. They are autoloading reels, so you don't have to monkey for too long in the dark. I loved them.
-James
88-91 civic/crx-
PM8 CRX Hf ecu $5
Del Sol/EG-
EK Civic-
Integra-
PR4 OBD0 LS ecu $25
P75 OBD1 LS ecu $75
DC map light $5
Prelude/Accord-
F23 distributor
Universal-
eghatch9295
Sep 4, 2010 09:13 AM
Bakeoff
Jan 24, 2007 04:13 PM
