FS: Innovate LM-1 RPM Kit ... Wideband o2 with onboard datalogging
Old Jan 23, 2007 | 08:23 AM
splitime's Avatar
Default FS: Innovate LM-1 RPM Kit ... Wideband o2 with onboard datalogging
FS: 1 Innovate LM-1 RPM kit.
Includes:
1x LM-1 Unit
1x O2 sensor
1x LM-1 to PC Serial Cable
1x Sensor cable
1x Power Cable
1x RPM pickup
1x RPM Converter (Aux Input #2) (can log 4 0-5v inputs)
My favorite unit on the market. I don't need 2 of them though. So pickup my spare for a deal
From Innovate:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The LM-1 is the industry's first and best complete wideband tuning system. A single self-contained unit combines a wideband air/fuel ratio sensor controller, a 6-channel data logger, and an easy-to-read backlit LCD display. This is the unit used by tuners, racers, and engine builders the world over.
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
* World's only fully-digital wideband controller.
* Up to 6 Channels of data logging.
* Portable/ Handheld.
* Display both A/F and Lambda readings in real-time.
* Auto calibration to compensate for changes in temperature, altitude, and sensor condition.
* Two user configurable analog outputs.
* LogWorks - award winning tuning software.
The instrument can sample and store 6 channels of data- air-fuel-ratio and up to 5 other sensor data channels- internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included LogWorks software or any standard spreadsheet program:
The LM-1 also features two analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 1 volt = 10 AFR (.6 lambda) and 2 volts = 20 AFR (1.3 lambda). With the provided LM Programmer software these analog outputs may also be configured by the user.
RPM KIT:
The RPM Kit ($429) is comprised of the basic kit plus the LMA-2 (RPM Converter.) This cable contains a circuit to convert a tach signal into an analog RPM signal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other 0-5 V analog sensors from your vehicle
All gear needed for $325 Shipped. This is confirmed working and is one of the nicest units on the market. Onboard datalogging = sex.
I can also plug in the LM-1 box to my car and display its working 100% for buyer. Just an extra confirmation
Modified by splitime at 12:51 PM 2/21/2007
Old Jan 30, 2007 | 10:41 AM
splitime's Avatar
Default Re: FS: Innovate LM-1 RPM Kit ... Wideband o2 with onboard datalogging (splitime)
No one cares about their motor eh.
Old Feb 2, 2007 | 08:29 PM
KENetics1's Avatar
willling to do 325 shipped?
Old Feb 7, 2007 | 09:33 AM
splitime's Avatar
Default Re: FS: Innovate LM-1 RPM Kit ... Wideband o2 with onboard datalogging (KENetics1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">willling to do 325 shipped?</TD></TR></TABLE>
PM'd. For people in reasonable distance... 325 shipped is acceptable.
AznPrideYo
Apr 9, 2008 07:46 AM
B--RYAN
Aug 29, 2007 04:40 AM
B--RYAN
Dec 11, 2006 07:10 AM
oryanh
Apr 9, 2004 01:44 AM
civictypenos
Nov 28, 2003 09:43 AM
