Rear Channel Speaker (Amplified Subwoofer)
Old Jan 23, 2007 | 06:38 AM
wxman13's Avatar
Default Rear Channel Speaker (Amplified Subwoofer)
Anyone ever adapted the rear center amplified sub speaker that I believe came standard on the Vtec Preludes, into a lude without the rear center speaker, I believe it requires a amplifier, not sure how it wires into the factory radio?
Modified by wxman13 at 8:36 AM 1/23/2007
Old Jan 23, 2007 | 06:42 AM
Lewdin' Incognito's Avatar
Default Re: Rear Channel Speaker (wxman13)
EDIT: Sorry, I was reading the post wrong.
Yes you can, all you really need is a small amp and sub that fits if you can't get the OEM parts.
(ps, vtech is a phone - vtec is a honda )
Modified by Lewdin' Incognito at 8:52 AM 1/23/2007
Old Jan 23, 2007 | 07:18 AM
kulrevon's Avatar
many people have installed that setup into preludes that did not originally have it. Some people have found the harness some people haven't. if there is no harness it is not that hard to wire. Its harder to find all the parts.
Old Jan 23, 2007 | 07:52 AM
mt23vtecbb2's Avatar
Default Re: Rear Channel Speaker (kulrevon)
yep installed this in my 96 si, it came out of a 93 vtec. and swaped the stock sub with a infinity sub, still running the stock amp. it sounds good. just a few wires to hook up. simple.
Old Jan 23, 2007 | 12:07 PM
veetak's Avatar
How did you wire the amp up without the plug? I tried soldering them but it was too cramped and the solders ended up sucking and breaking a lot
Old Feb 2, 2007 | 06:11 PM
wxman13's Avatar
Default Re: Rear Channel Speaker (mt23vtecbb2)
I now have the amp, but no wiring harness, do you know the pin outs for the amp?
If I can get that info I should be able to wire it up no problem I hope?
Robert
Old Feb 2, 2007 | 06:20 PM
InvaderTrax's Avatar
I got pretty serious with my setup. I've also got another complete setup for sale if anyone wants one
Old Feb 3, 2007 | 12:23 PM
Turbocivic94's Avatar
Default Re: (InvaderTrax)
I bought mine from junkyard for $20 and hooked it up to one of the rear speakers.
Old Feb 5, 2007 | 07:15 AM
wxman13's Avatar
What model infinity sub did you use?, did it fit in the 6x9 bracket space?
Thanks,
Robert
Old Feb 5, 2007 | 12:18 PM
i cant remember the model number. i bought them as a pair. only needed one, so i still have the other one. brand new. i think it was a 612 or some thing. it sounds grate. and i had the plug for the amp, just looked at my wiring diagram. real simple. if you want the other 6x9 ill take like 50 shipped for it.
Old Feb 5, 2007 | 01:34 PM
Pilky's Avatar
I'v never looked at the speaker or the wiring for that back speaker. Does it just connect to one of the rear speakers?
Old Feb 6, 2007 | 01:45 PM
P13_mein's Avatar
The harness in the VTEC preludes leads from the plug to each of the speakers, ACC and ground and then of course two to the 6X9 woofer.
I have the entire VTEC rare console for sale, speaker+ frame+ mini amp+cover+94 up rear seat divider.
Old Feb 6, 2007 | 02:20 PM
xthekidx's Avatar
Default Re: Rear Channel Speaker (P13_mein)
all vtec preludes have a stock amp and sub in them?
i have an o1 base and ive never found the amp or sub.
its a dumb question, dont flame, just enlighten me kindly.
Old Feb 6, 2007 | 02:21 PM
sivikvtec's Avatar
Default Re: Rear Channel Speaker (xthekidx)
just 93-96 have it
Old Feb 6, 2007 | 02:27 PM
95SE's Avatar
I am not sure about your '01, but this thread is about the 4th gen (92-96) vtec
Old Feb 6, 2007 | 02:29 PM
xthekidx's Avatar
Default Re: Rear Channel Speaker (95SE)
yeah i kinda thought so.
before i went aftermarket with subs and an amp, the stock system bumped pretty good for being stock, so idk; maybe there is an amp for mids somewhere.
Old Mar 21, 2007 | 06:21 PM
wxman13's Avatar
I am now hooking the rear speaker up, I have the original Honda rear 6x9 speaker, I will have to wire it up to the Honda amp, is there any way to tell which terminals on the speaker are + and - ?
They are not labeled on the Honda speaker.
Thanks
Old Mar 26, 2007 | 06:54 PM
wxman13's Avatar
Does anyone know if it really matters on the + and - terminals in this setup?
The speaker is not labeled + or -
Thanks,
Robert
Old Mar 26, 2007 | 06:58 PM
P13_mein's Avatar
the wider prong is +
Old Mar 27, 2007 | 04:39 PM
wxman13's Avatar
There is no difference in the size of the connectors on the original Honda center speaker.
Robert
Giggybobble
Audio / Security / Video
Oct 18, 2009 10:38 PM
jonaldjenkins
Honda S2000
Apr 9, 2008 12:11 PM
doggworld1233
Jan 15, 2007 08:37 PM
AndyD
Jul 23, 2003 05:37 PM
