clutch question. any difference between gsr and ls?
Old Jan 22, 2007 | 11:56 PM
dem0nk1d's Avatar
Default clutch question. any difference between gsr and ls?
I recently bought 97 Ls long block, pulled the clutch off today. Damn is it shot, worn out and, all the way to the rivets. Also I bought it with a tranny the guy said it's a gsr, but their is no sticker on it. Someone said to pull the case off to check how many teeth it has on the diff. Crazy talk... But I guess my question is, does it matter if the clucth is for a gsr or ls? Are they different. Also from what I know their is a 6 bolt fly wheel and a 8 bolt.
Old Jan 23, 2007 | 12:34 AM
BlueIntegraBoy's Avatar
Default Re: clutch question. any difference between gsr and ls? (dem0nk1d)
Clutches are the same
Old Jan 23, 2007 | 09:20 AM
95 integra's Avatar
Default Re: clutch question. any difference between gsr and ls? (BlueIntegraBoy)
Put the trans in 5th gear...the input shaft should turn 3.5 times for 1 turn of the diff/axles. 3.25 (ish) is a LS trans and 3.75 is a B16
jamelin
Jul 24, 2009 12:11 PM
97RSTEG
Jan 15, 2007 12:35 PM
the.hamburglar
Mar 2, 2004 09:33 PM
hatchattak
Feb 11, 2004 05:24 AM
blackout
Feb 6, 2002 07:41 AM
