weird
ok so my friend has cut springs on his car and the car sits pretty low so then he got some coilovers from ebay so we installed them and lowered them all the way down but it didnt go as lowest as it was before so then we went to go drive it and like when you accelerate to pick up speed the wheels start like to vibrate so we though its probably bad alighment or balancing cause his tires are pretty wasted from the inside part of the tire cause of camber so then we decide to put back the old cut springs to see if it would do the same thing and it didnt the car would drive smooth when picking up speed no vibrations or nothing why could it of been vibrating when we installed coilovers
because your friend was ghetto and cut the springs..... the tires wore funny.
when you put the new springs on, the tires sat at a different angle, causing the wobbling.
its common sense.
put the new spring combo on, and buy new tires, alignment, etc.
everytime you half-*** something, your car is going to wobble. <----true story.
its common sense.
i knew it i i told him it was his tires that made it vibrate and he kept on telling me i was wrong then i told its probably cause the tires got use to the way the car was drop before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">
everytime you half-*** something, your car is going to wobble. <----true story. </TD></TR></TABLE>
Everytime you post a silly *** question, Tippy posts a silly *** comment and google pic.
Buy real suspension and use periods. Then come back to H-T.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Everytime you post a silly *** question, Tippy posts a silly *** comment and google pic.
Buy real suspension and use periods. Then come back to H-T.</TD></TR></TABLE>
seriously, use some perios or commas. you are banging out some long sentences.
it is hard as **** to follow what you are trying to get across. punctuation is not that hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oodie »</TD></TR><TR><TD CLASS="quote">Why the satin tampax? </TD></TR></TABLE>
It's for his first PERIOD.
*Sigh*, subtilty is lost on the masses...
*Sigh*, subtilty is lost on the masses...</TD></TR></TABLE>
I got it, yay!
I got it, yay!
When I bought my 91 hatch dx, it had cheap *** tom motorsports coil overs and whenever I accelerated the steering would wobble. the car had new tie rods and ball joints. 2 tranny mounts were shot so I replaced them, it didnt vibrate as much, so I raised the suspension a little and it was fine, I never knew what the problem was.
If your friends steering is shaking only when it accelerates, I doubt its the tires else it would shake all the time...
PhatRoyale
Suspension & Brakes
13
Oct 8, 2008 07:58 PM
