help fix, my brake light stays on
Old Jan 22, 2007 | 08:27 PM
'Accord Ex''s Avatar
Default how to fix cencors
my break light stays on. it is cold weather and it stays on even though i know the e-brake is not on.
Old Jan 22, 2007 | 08:37 PM
YeuEmMaiMai's Avatar
Default Re: how to fix cencors ('Accord Ex')
it is your brake light switch.... you can repair it if you can get the parts or get another one
Old Jan 22, 2007 | 09:21 PM
Default Re: how to fix cencors (YeuEmMaiMai)
how
Old Jan 22, 2007 | 10:27 PM
momstaxi's Avatar
you might be low on brake fluid in the master cylinder
Old Jan 22, 2007 | 11:27 PM
SuperSlow's Avatar
sounds like lines are grounded out. what is cencor?
Old Jan 23, 2007 | 04:59 AM
Ross 2.0's Avatar
In a Junkyard near you.
the brake lights or the "brake" light?
Old Jan 23, 2007 | 05:25 AM
Default Re: how to fix cencors (ScruffyTheJanitor)
just the light inside the car not the actual tail light. maybe it because i washed the motor and it just got wet or moved or somthing
Old Jan 23, 2007 | 05:28 AM
Ross 2.0's Avatar
check your brake fluid level. then if it's not low you need to replace the brake reservoir cap.
Old Jan 23, 2007 | 05:30 AM
TouringAccord's Avatar
H-T Order of Merit
could your brake reservoir cap be loose?
Old Jan 23, 2007 | 11:37 AM
SuperSlow's Avatar
check your rear window brake light bulb to see if it works. most likely your issue.
Old Jan 23, 2007 | 11:41 AM
porc933's Avatar
What year accord is it. If it's a 4th gen I had the same problem the only thing that worked for me was to go to the yard and get another harness for the lights just the part that connects to the bulbs; or just take the light out of the spedo. But u will just have to check your lights every so often to keep the fuzz off ya.
Old Jan 23, 2007 | 12:59 PM
The-Kid's Avatar
Default Re: how to fix cencors (SuperSlow)
i agree with Superslow. On my 96 Accord coupe, the brake light on the dash was on. I told my mom to press the brake pedal for me and turns out the bulb was out. Weird!
Old Jan 23, 2007 | 03:09 PM
hondadude's Avatar
Default Re: (ScruffyTheJanitor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScruffyTheJanitor &raquo;</TD></TR><TR><TD CLASS="quote">check your brake fluid level. then if it's not low you need to replace the brake reservoir cap.</TD></TR></TABLE>
Quick test for the brake fluid level sensor, take the cap off and turn it upside down so the float goes to the cap. That light BETTER be off then!
FWIW I've had several people <U>say</U> their brake fluid level is okay, but they are seeing a 'scum' line on the inside of the reservoir; It's best to take the cap off to check the fluid level.
Old Jan 23, 2007 | 07:18 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">check your rear window brake light bulb to see if it works. most likely your issue.</TD></TR></TABLE>You guys are confusing...
We need the original poster to say which brake warning lamp.
One warning lamp is for handbrake & brake fluid.
Another warning lamp is for burned-out brakelights in back.
I wonder which one he's got? I'm guessing it's the handbrake/fluid warning since he started out talking about the handbrake.
SCinCA
Oct 6, 2014 06:35 PM
nicolaselias
Dec 22, 2011 03:58 PM
white99accordEX
Dec 22, 2005 04:08 AM
Andrea_Aunie
Oct 20, 2001 11:46 AM
D-Day
May 23, 2001 06:31 PM
