H22 EK Question - Problems with car shaking between 20-50 mph (axle combination?)
I have an H22 EK and it has a problem shaking/vibrating whenever accelerating between 20-50 mph. Before 20 or after 50 mph, the car seems fine.
Note, this is only when in gear and accelerating..
SETUP:
1997 Civic EK
H22
Hasport EKH2 Mounts
M2B4 jdm LSD h22 transmission
axle combination:
H22 mid-shaft and 88-89 Integra Axles on both sides with regular H22 Inners...
I've tried using 90-93 integra axles and it was hardly driveable (shook too much)
I'm thinkin its the axles still (maybe because of the LSD h22 tranny?), but not sure.
Maybe it's the wheel hub bearing?
Any suggestions appreciated!!!
SETUP:
1997 Civic EK
H22
Hasport EKH2 Mounts
axle combination:
Would be odd that it wouldn't do it over 50 mph, but maybe your tires are out of balance or warped. I don't know much about the axles though, sorry.
if the tires aren't balanced.. it should shake more at higher speeds
or at least that's what i'm thinking..
anyone else have any opinions?
Thanks
Thanks
i had same problem but with dss stg3's with ekk1 mounts (k20a) swap... I shipped axles back & it was determined by DSS that they were slightly too long & binding - so they made me a new pair
did you search "h22 axles" limit to hybrid forum?
