Painting my car, need a little help.
Old Jan 22, 2007 | 06:18 PM
low91rex's Avatar
Default Painting my car, need a little help.
Ok this is my issue. Im getting ready to spray my car and I don't have a compressor so obviously I have to buy one. Now I work at sears so I can get a discount on a craftsman compressor. Wich one do I buy? Im on a super super tight budget and I saw this one its got this:
125psi max
1HP
7 GAL tank
Its like $159 w/o my discount. Is this good enough to paint my car? and use like an impact? thanx in advance
p.s. I didnt know where exactly to put this so I put it here
Old Jan 22, 2007 | 06:39 PM
low91rex's Avatar
Default Re: Painting my car, need a little help. (next21)
nobody
Old Jan 22, 2007 | 06:47 PM
mike9571's Avatar
Thats too small, you will run out of air to often while painting. When painting you cant stop you have to continuously spray unless paint is flashing. Just pe patient, save, and get a larger compressor.
Old Jan 22, 2007 | 06:57 PM
low91rex's Avatar
Default Re: Painting my car, need a little help. (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">Thats too small, you will run out of air to often while painting. When painting you cant stop you have to continuously spray unless paint is flashing. Just pe patient, save, and get a larger compressor. </TD></TR></TABLE>
Thanks anything in particular I should look for other than a bigger tank? What size do you recommend? and cant I just leave the motor running? that will give me enough air?
Old Jan 22, 2007 | 07:18 PM
WanaBeFaster's Avatar
I'd get atleast 3hp, 10 gal.
Old Jan 22, 2007 | 07:20 PM
mike9571's Avatar
Default Re: (WanaBeFaster)
The smallest compressor ive used is a 19gal. And that was fine.
Old Jan 22, 2007 | 07:35 PM
low91rex's Avatar
Default Re: (mike9571)
I guess I have some more shopping around to do
And what about the psi rating? is 125 enoughto spray some paint?
Old Jan 22, 2007 | 08:13 PM
powerflow's Avatar
Default Re: (next21)
Thats double what I have going into my guns. I use a regulator and adjust it to 50-60 psi into the air line. Sounds like you need to do more homework. Practice on some junk panels to get the feel for it.
Old Jan 23, 2007 | 02:55 PM
low91rex's Avatar
Default Re: (powerflow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow &raquo;</TD></TR><TR><TD CLASS="quote">Thats double what I have going into my guns. I use a regulator and adjust it to 50-60 psi into the air line. Sounds like you need to do more homework. Practice on some junk panels to get the feel for it. </TD></TR></TABLE>
Yeah I have no idea how to go about this. is there any links you know of that will help me out? And yeah I will definitely practice before I do it.
Also how much does tank size really matter? Im probably only gonna use it a few times to paint my friends cars. I mean a cant just leave the motor running? I don even know how it works. does the pump fill up the tank and just use that? Thanks fo the help anyway guys
Old Jan 23, 2007 | 03:03 PM
mike9571's Avatar
Check out autobody101.com
There is alot of useful information on that site. Like on here make sure you search becasue all the basics have been covered 1000 times.
Old Jan 25, 2007 | 08:31 AM
Mr. Wonderful's Avatar
the most important thing to look for in the compressor is the cfm rating. get the highest possible.
Old Jan 25, 2007 | 09:09 AM
CBURKE's Avatar
You can use the one your looking at if you like, but you can only do parts. You will not be able to spray the car all at one time. That is what I have to do with mine. Paint the finders, then the doors, trunk, hood. then what ever is left over. It's a pain, but it is better then spending the money on a bigger one if you don't plan on doing this for a living or don't have the money. Good luck!!!
Old Jan 25, 2007 | 02:41 PM
low91rex's Avatar
Default Re: (CBURKE)
Cool man. Got any pics of how your car came out?
Old Jan 26, 2007 | 05:07 AM
CBURKE's Avatar
let me see,
my hood:
My wheels:
This hole car, little by little:
Bikes seem to be the easy'es to do:
It's still not all but back togther yet, but you get the idea..........
Old Jan 26, 2007 | 05:09 AM
CBURKE's Avatar
And I am all self tought...................
Old Jan 26, 2007 | 05:22 AM
kidkombo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">And I am all self tought...................</TD></TR></TABLE>
same here
Old Jan 31, 2007 | 07:20 PM
NAlover's Avatar
Default ...
I was thinking today is my compressor will be good to paint a car.... I guess yes it's its a 7hp 60gal. compressor so let's see how it works out while I paint my car
Old Jan 31, 2007 | 08:53 PM
ERNIEinDAteg's Avatar
you should just rent a compressor for like 2days that way you dont have to buy it
Old Feb 1, 2007 | 12:11 AM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
Default Re: (ERNIEinDAteg)
since you work at sears get atleast the 30 gallon tank or a 20 gallon tank thats run with a belt with a high cfm.. gl to you.
Old Feb 1, 2007 | 08:59 AM
DANG YO's Avatar
cburke. your paint work isnt that great.
Old Feb 1, 2007 | 07:18 PM
low91rex's Avatar
Default Re:
Well Its too late I just bought a 15GAL compressor. I just didnt have enough money to get a 30GAL
So Im gonna go down to harbor freight and pick me up a spray gun. Lets see how this turns out
Old Feb 1, 2007 | 07:26 PM
vsmhatched's Avatar
Default Re: Re: (next21)
the 12.99 harbor freight guns.... super shitty, doesnt even have fan control and the spray pattern is terrible and cannot be controlled. Well, I guess i think you should have waited until you had some more money to spend on a compressor and a decent gun. That 15 gallon taank is gonna be working hard to keep up with how many cfm's your gonna be using. Also there are some starter guns that are ok to use for nothing over 150..I think finishline has a decent starter HVLP gun that atleast can control fan, fluid and air control. But i guess we'll see how it turns out for ya..good luck bro
Old Feb 1, 2007 | 07:35 PM
low91rex's Avatar
Default Re: Re: (GreyDel)
Thanks, I couldnt help but notice you ASE certified. Thats awesome, what are you certified in?
Old Feb 1, 2007 | 07:37 PM
vsmhatched's Avatar
painting....took the b2 test at school
Old Feb 1, 2007 | 07:39 PM
vsmhatched's Avatar
i wanna take the test B5..mechanical or something like that, my teachers i have now say that thats the hardest test to pass...I'm also try to go thru and get I-Car point takencare off too, but its pretty expensive. I go to school for autobody collision and fabrication stuff, so that all kinda helps me out
