Best Suspension for Daily Driver and some autoX CRX-B16
Old Jan 22, 2007 | 02:59 PM
gringo7718's Avatar
Default Best Suspension for Daily Driver/Auto-X CRX-B16
i have a crx with a b series and i use the car as my daily driver with the once a month AutoX visit. I am currently using Tein S-tech/KYB gr2 which works nice for street driving, but the springs are way too soft for autoX (especially with the added weight of the motor).
I am looking for something that will not lower the car too much but offer a little stiffer spring rates for my aggressive driving. I would like the car to have better balance without slamming it. i dont think i really need full coilovers or really stiff spring rates. i am looking for a compromise between streetability and performance. please help me.
Modified by gringo7718 at 10:20 PM 2/1/2007
Old Jan 22, 2007 | 03:15 PM
crxnj's Avatar
Default Re: Best Suspension for Daily Driver/Auto-X CRX-B16 (gringo7718)
keep the s-tech springs but get some kyb agx shock asorbers.
gr-2's are really only stock replacments.
Old Jan 22, 2007 | 04:45 PM
SIred91's Avatar
Rainman
Default Re: Best Suspension for Daily Driver/Auto-X CRX-B16 (mr.speaker)
Koni sports.
/thread.
Old Jan 22, 2007 | 06:46 PM
M15's Avatar
M15
Default Re: Best Suspension for Daily Driver/Auto-X CRX-B16 (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Koni sports.
/thread.</TD></TR></TABLE>
Yeah the S-tech's should be fine for autocrossing if you get a stiffer shock, I had a B16 CRX with S-tech's and AGX's rode nice but didn't handle for crap. Koni is honestly the best thing you could buy.
Old Jan 23, 2007 | 02:20 PM
gringo7718's Avatar
Default Re: Best Suspension for Daily Driver/Auto-X CRX-B16 (M15)
thanks for the input
i have been researching springs/spring rates and Tanabe GF210 seem to be offering the specs i am looking for but i dont know what to do.
What would you reccomend; Stiffer Shocks or Stiffer Springs?
http://www.tanabe-usa.com/springs/gf210.asp
TANABE GF210
Drop: 1.3"
Front: 6.0 Kg/mm 336 in/lbs
Rear: 2.7 Kg/mm 152 in/lbs
TEIN S-TECH
Drop: 1.5"
Front: 4.8 Kg/mm 269 in/lbs
Rear: 2.2 Kg/mm 123 in/lbs
PROGRESS W/ B-SERIES
Drop: 2.0"
Front: 6.4 Kg/mm 360 in/lbs
Rear: 3.5 Kg/mm 200 in/lbs
EIBACH SPORTLINE
Drop: 1.7"
Front: 4.9 Kg/mm 274 in/lbs
Rear: 97/230 in/lbs
Modified by gringo7718 at 11:31 PM 1/23/2007
Old Jan 23, 2007 | 02:44 PM
HondaFerris's Avatar
ever look into omnipower?
Old Jan 23, 2007 | 03:01 PM
djphonics's Avatar
+1
[/thread]
Old Jan 23, 2007 | 06:07 PM
M15's Avatar
M15
Default Re: Best Suspension for Daily Driver/Auto-X CRX-B16 (djphonics)
[QUOTE=gringo7718]
QUOTE]
Stiffer shocks, but try to get them matched up if you go with a full coilover setup. but if nothing else Koni is the way to go
Old Jan 28, 2007 | 04:44 PM
gringo7718's Avatar
BUMP
Old Feb 1, 2007 | 01:21 PM
gringo7718's Avatar
Old Feb 1, 2007 | 01:27 PM
allblacksrt4's Avatar
does megan make a coilover kit? i really liked there kit on my buddies 4door eg.
Old Feb 1, 2007 | 01:35 PM
Jonas99's Avatar
Default Re: (allblacksrt4)
h&r sports + kyb agx + rear sway
Old Feb 1, 2007 | 01:39 PM
goforbroke's Avatar
MEAT PATTY
None of those springs are really want you want if you want your car to perform decently at an autox. Thats the only problem about springs they are designed to compensate for the engine so they make them stiffer in the front end. Which makes sense, but not for autox. You want the rear to be stiffer in then the front.
Old Feb 1, 2007 | 02:10 PM
jdm_ef9_b16's Avatar
ground controls and agx's or koni's
Old Feb 2, 2007 | 11:57 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
my next set up is agxs with swift springs, ill give a review when i get them installed.
Old Feb 2, 2007 | 02:26 PM
ef-hatchcrap's Avatar
Default Re: (ComeOnKip)
My buddy pat had the setup as you and he was running kyb/agx with nuespeed race springs.
Car drove very nice handle awsome. That is what I am going to buy when I get my income tax money back.
Old Feb 3, 2007 | 06:45 AM
hai_tech's Avatar
i hav d2 racing damper kit very nice 36 way adjustment
Old Feb 3, 2007 | 08:49 AM
HatchMo's Avatar
k-sport nuff' said
Old Feb 3, 2007 | 08:56 AM
LoveOfMoney's Avatar
function form...
Old Feb 3, 2007 | 09:11 AM
Crx Jimmy's Avatar
Default Re: (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">None of those springs are really want you want if you want your car to perform decently at an autox. Thats the only problem about springs they are designed to compensate for the engine so they make them stiffer in the front end. Which makes sense, but not for autox. You want the rear to be stiffer in then the front.</TD></TR></TABLE>
X2
Old Feb 20, 2007 | 04:50 PM
gringo7718's Avatar
Default Re: (Crx Jimmy)
Thanks for the Advice!
I ended up getting a set of Tokico Illumina 5-way adjustable shocks and i am happy with the results. They also give me room to upgrade my suspension to stiffer springs in the future if I want.
d00d00dumb87
25
Apr 15, 2010 06:10 PM
perpetualburn
72
May 9, 2007 05:09 PM
gringo7718
Suspension & Brakes
Feb 6, 2007 02:34 PM
tonyrd1
Jul 18, 2004 08:55 PM
SilverDc2
Jun 22, 2003 04:07 PM
