CRX OBD II/ D16Y7 swap
Old Jan 22, 2007 | 01:29 PM
Absolut_D's Avatar
Default CRX OBD II/ D16Y7 swap
Ok so My D16A6 finally gave up the ghost, no compression on really low on 3 of the Cylinders, so rather than deal with it, firgured for a swap, but not anything big...question is what would all have to happen/ required to make it possible and any pontential problems with it, and where can I find a kind of "How-To" for this kind of swap? thanks all...
Old Jan 22, 2007 | 02:07 PM
e jay one's Avatar
Default Re: CRX OBD II/ D16Y7 swap (Absolut_D)
use your a6 intake mani, dizzy, alternator, and o2 sensor and run the y7 obd0
Old Jan 22, 2007 | 02:18 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: CRX OBD II/ D16Y7 swap (e jay one)
the only thing you'll have to do also is either swap the fan switch from the back of the A6 block to the Y7 (if it has a threaded hole) or run the wires from there to the thermostat housing of the Y7 motor.
denniscoles
May 4, 2007 05:52 PM
Schaz
Feb 12, 2005 02:58 PM
PFSeg
Oct 19, 2004 07:23 PM
yaleforizzle
Jul 27, 2004 09:16 AM
