EDM Accord. Does anyone know about H22 swap
I'm going to get a 2.0LS EDM Accord coupe, I want to get a 2.2VTI engine (H22) in that bad boy does anyone have any experience i believe the engine is a F20Z? does anyone know of any UK websites with such info. Any help would be awesome.
Thanks in advance. B
what chassis is it?
but if its equipped with f20z motor it will be identcial in most, if not all aspects to swapping 5th gen f22bx to h series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">what chassis is it?
but if its equipped with f20z motor it will be identcial in most, if not all aspects to swapping 5th gen f22bx to h series.</TD></TR></TABLE>
Of course, the chassis i forgot to mention. its a 94-97 2DR chassis, I'm certain its identical to the US 2DR apart from the steering wheel is on the other ( correct
) side of the car.
H22 engines are in abundance from the 1995era prelude in the UK so i expect i shall aquire one of those, my main concerns are ECU and Tranny
) side of the car. H22 engines are in abundance from the 1995era prelude in the UK so i expect i shall aquire one of those, my main concerns are ECU and Tranny
You'll need the ECU for sure. Any F series should match up with any H series, so if you are money crunching, then you could use the stock transmission. Your best bet would be, to get the whole motor, ECU and Tranny.
