Automatic to B16 Tranny Swap
Old Jan 22, 2007 | 11:33 AM
Y2KGSR's Avatar
Default Automatic to B16 Tranny Swap
I've been thinking about doing this swap for awhile, but then today on the way home from work, my tranny blew out. My lovely wife towed me home - 20 miles - in her magnificent Saturn, ha ha. So, as it sits in the backyard, with my tax return check on the way, I need to get my ducks in a row and figure out everything I need for the swap. Guess it's time to pull the GSR out of the garage.
Any help or suggestions on how to go about this, a list of needed parts, etc would be appreciated. Just wanted to talk to those who have done this first hand, but I'll be doing a search also.
Old Jan 22, 2007 | 11:50 AM
TYPE-R#945's Avatar
Default Re: Automatic to B16 Tranny Swap (Y2KGSR)
your going to need, manual trans (duh),master cylinder,slave cylinder,manual pedals,manual ecu,clutch line,you might little things i cant remeber right now, ihave a hang over....
Old Jan 22, 2007 | 12:13 PM
DA6righthand's Avatar
Default Re: Automatic to B16 Tranny Swap (TYPE-R#945)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TYPE-R#945 &raquo;</TD></TR><TR><TD CLASS="quote">your going to need, manual trans (duh),master cylinder,slave cylinder,manual pedals,manual ecu,clutch line,you might little things i cant remeber right now, ihave a hang over.... </TD></TR></TABLE>
you can actually keep your auto ecu. you can wire it to trick the ecu to think it's in park so the engine can free rev. you need: trans, flywheel, flywheel bolts, clutch, clutch bolts, slave cylinder (if it's not incl. with trans), clutch hardlines, clutch master cylinder, clutch pedal, manual brake pedal, shifter, shift linkage...and i think that's it. you DON'T want to use the whole brake/gas pedal assembly if you want cruise control. the brackets for the cruise control cable are different on the at and mt pedal assemblies. and the at cruise control cable is longer than the mt cable. SO just take the mt brake pedal and put it on the at assembly.
this swap isn't just a weekend deal. research as much as you can check out team-integra.net and clubintegra.com for as much info as you can get. i was going to swap my car. i bought all of the parts, realized it's too much of a pain in the *** and decided to keep my car an auto. 'm tryin' to find an auto b16/gsr trans and messin' with that. revalving the valvebody, 3400 stall converter...nice for and auto...but that's a ways down the road. the trick is findin' the trans...
Old Jan 22, 2007 | 02:28 PM
Y2KGSR's Avatar
how can I tell if its a B16 tranny???
Old Jan 22, 2007 | 02:47 PM
TYPE-R#945's Avatar
i have one to save you the trouble ....
toofast4you1989
Nov 15, 2007 11:57 AM
nickEM2slo
Honda Civic (2001 - 2005)
Sep 26, 2007 07:35 AM
jaydmef9
Feb 22, 2007 05:58 PM
Turbo25Ek
Dec 9, 2006 12:32 PM
99teggsr
Dec 4, 2003 10:31 AM
