FS/ FT:::::: 93 Accord ex coupe::::::JDM H22 w/ LSD and other mods ******Northern Virginia*******
Means of Contact: PM or Cell (703) 895 4015
Description: FS/FT 93 Accord EX coupe with JDM H22 and LSD, Black w/ Tan cloth interior
Miles: 208xxx on chassis/ 20k on motor/ 6k on swap (purchased from JEI in Sterling, VA. I have all the papers and receipts for everything!)
**********SOLD!!!*********
This has been my daily driver for the past 4 ½ years and I love this car. I recently got married and my wife hates this car because I keep putting money into it. I had major plans for it but I have to let it go. No car is more important than a healthy marriage to me. I just want someone who will take care of this car like I have. I’m the third owner and the past 100k miles have been traveling back and forth from South Carolina to Virginia to see my now wife (we dated for 5.5 years before we got married). I will take trades for EK hatches or sedans, 98-02 Accords, 98+ integra sedans.
THE TRADE MUST BE STOCK OR LIGHTLY MODIFIED AND BE RELIABLE. NO SWAPPED/BOOSTED CARS.
I have $2k to put with my car to trade for yours. Let me know what you have. The worst I could say is no.
Mods:
Engine:
-Ebay 3" short ram prelude intake
-Megan Racing header with 2.5" collector mod
-Carsound 2.5" highflow cat
-2.25" Custom Exhaust with stock looking tips
-DIY Crinkle coat red valve cover
-Type S pistons (**Phil at JEI told me it had type S pistons. The compression test read 250 psi all accross the board and there is gasket sealer on the oil pan which leads me to believe that it has some type of high compression pistons)
-Type S cams (**Phil at JEI also told me it had type s cams. The head looks lighter than the block which leads me to believe that it's been bead blasted and possibly ported)
-Chipped p06 (J-K Tuning h22 basemap) with zif socket. Also has dual stage rev limit and check engine shift light.
-***Car has working A/C, P/S, and cruise control! A/C blows cold***
-tranny has no grinds
-Brand new Distributor
Parts replaced at time of swap:
-timing belt, balancer belt, water pump and all seals on that side of the motor
-Cap, rotor, and new plugs done at swap
-H23 Manual tensioner conversion
-all coolant hoses
-This motor was done right and installed by me and an experienced Honda Technician
-It will definitely through you back into your seat when vtec engages!
Suspension:
-Tein S-tech springs on Kyb Gr2 struts
-Megan racing front upper strut bar
-ST rear sway bar (uninstalled)
-Alignment done with new tires (2k miles ago)
-Front poly sway bar bushings and end links
Brakes:
-Four wheel disc brakes
-All four pads (akebono) and new master cylinder done 20k miles ago
-Brembo Blank rotors
-Honda brake fluid
Exterior:
-Amber corner lenses
-Clear bumper lenses (I still have the amber too if you want them)
-Stock EX Alloys painted flat black
-Brand new Bridgestone Potenza G009s all around (less than 2k miles)
-hood and front bumper has rock chips and a few dings
-rear bumper and trunk need some minor body work.
-Paint could use some TLC which is common for a 14 year old car.
-Custom LX grill with mesh painted black with accord emblem
Interior:
-Aiwa CD player
-ITR shift ****
-DIY short shifter
-Recently deep cleaned (took out all the seats and simple greened everything)
-Has a few minor, treatable stains on carpet and rear seat.
The Bad:
-Minor dings and scratches typical for a car this old
-Idles high when the motor is cold but goes down and idles perfect when warmed up (no surging)
-Antenna is broke
More PICS:
Current Motor pic (I forgot to put the spark plug cover back on)
bumper damage
Modified by exratedaccord93 at 12:03 PM 1/29/2007
Modified by exratedaccord93 at 10:35 PM 2/5/2007
Mods:
Engine:
-all coolant hoses
Suspension:
Brakes:
-Honda brake fluid
Exterior:
Interior:
-Aiwa CD player
-ITR shift ****
-DIY short shifter
The Bad:
-Antenna is broke
More PICS:
bumper damage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riggitybizzang »</TD></TR><TR><TD CLASS="quote">Hit up my email. I have a few questions. harterd-at-uwplatt.edu</TD></TR></TABLE>
Emailed and PMED
Emailed and PMED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">up</TD></TR></TABLE>
thanks
10
thanks
10
whoever buys this car is going to get a lot of car for the money.
also it's not played out like a civic or integra
btw: this car rolled out on a '06 Si with i/h/e
Modified by thehatchninja at 10:59 AM 1/24/2007
