VSS issue......Please help me....My question is very detailed.
Ok yall. I'm getting a code 17 (VSS) on my JDM B16a w/ PW0 ECU. My Speedometer work fine but I dont think Vtec is working because my rev limiter is hitting at about 7500 rpms. I've tried resetting the ECU and nothing is making the code go away. Do I need to swap out the cluster?? Thanks for your help I really need to get this thing working.
Thats a very good question...I'll be honest. I really just noticed it because of another problem. When I got the car I assumed everything was fine until I had to check something ealse witch in turn lead me to this problem. So for all I know Vtec could never have worked and the previous owner was a complete idiot and didnt know how to work on his own crap and now I have to figure it all out.
It should be 8200. If not it could be a couple of things, VSS, knock sensor, oil pressure, vtec solenoid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">Ok yall. I'm getting a code 17 (VSS) on my JDM B16a w/ PW0 ECU. My Speedometer work fine but I dont think Vtec is working because my rev limiter is hitting at about 7500 rpms. I've tried resetting the ECU and nothing is making the code go away. Do I need to swap out the cluster?? Thanks for your help I really need to get this thing working.</TD></TR></TABLE>
I have no idea what thats all about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">not to jack, but i have a b16a in my crx and i rev limit at 7500 as well. no CEL i thought that the limit was 8200 on these engines</TD></TR></TABLE>
I think the auto ecus have an earlier rev limit. Also keep in mind the stock tach could be off, verify with an aftermarket unit if necessary.
I FIXED IT!!! My cluster was missing one of those fawkin' screws in the back!!! Now Vtec kicks in for the first time since I've had the car!!! It's so retarded fast!!! I love it!!! Thanks yall
Its VSS, check if its working properly.
dthug
Aug 17, 2006 11:29 AM
