car cranks but wont turn over
Old Jan 22, 2007 | 09:19 AM
yoursupahero09's Avatar
Default car cranks but wont turn over
engine is b18c1. the car started and died. i just replaced the battery and the headlight and everything work. the car just doesnt want to start. it cranks up like its going to start and then it doesnt. help please. could this be a bad alternator??
Old Jan 22, 2007 | 09:21 AM
CRX T-Si's Avatar
Default Re: car cranks but wont turn over (yoursupahero09)
Have you check the usual causes....like firing order?
checked for FP?
or have fuel? (not a smart *** question but many have done this)
Old Jan 22, 2007 | 09:24 AM
RedEj8's Avatar
Default Re: car cranks but wont turn over (CRX T-Si)
Do you have fuel and spark?..check ALL of your ground wires.
Old Jan 22, 2007 | 09:29 AM
yes i do have fuel i just put 2 gallons into it. and what do you by spark?
Old Jan 22, 2007 | 09:30 AM
vlc92189's Avatar
u pull one plug out.. groud it to see if u see spark. i have same motor and the same problem happened to me.. it turned out to be i had no spark. it was the ignition coil inside the dizzy. hope this helps
Old Jan 22, 2007 | 09:33 AM
CRX T-Si's Avatar
Grab one of your buddies to help ya man. Doing this by yourself suxs.
Did you check your ECU fuse and wires? I had an incident where one wire was loose and when I pushed the ecu plug in one of the wire came out.
Old Jan 22, 2007 | 01:57 PM
btbomb's Avatar
also check the distributor, if you blew the small casing in there by messing with some electrical wiring the small rectangular module will look bulged, and the car wont start. happened to my car when i hooked up a tach
Old Jan 22, 2007 | 04:39 PM
Default Re: car cranks but wont turn over (btbomb)
okay so its not the starter and not the alternator, so it could be the distributor? how do i check if there is something wrong with that? where is the bulge in the module and how do i fix it or do i need to replace the distributor??
Old Jan 22, 2007 | 05:10 PM
Kafelatte's Avatar
might be your ignition coil or rotor. the rotor you can check just by looking at it. but the ignition coil you'll need a multimeter.
Old Jan 23, 2007 | 12:03 AM
dubzxallxstar's Avatar
check the ground...could be loose or chia pets growing around the cables.?
Old Jan 23, 2007 | 04:19 AM
Go_Race_Your_Self's Avatar
Two Piece
does it die right after it starts?? if it does check the starter
desiromeo812
Dec 18, 2008 05:35 PM
hybridmath
30
Jul 20, 2008 03:38 PM
CLE
11
Aug 1, 2006 08:23 PM
integra15
Nov 13, 2004 07:07 AM
Skip
10
Jan 29, 2004 07:42 PM
