Inspection time, need some secondary o2 sensor bypass advice
Old Jan 22, 2007 | 09:16 AM
soulrider4ever's Avatar
Default Inspection time, need some secondary o2 sensor bypass advice
I'm needing an inspection soon, and am running into some not so fun issues with my hondata ecu.
What I need to do is, swap my stock ecu in for inspection, but I throw a code for the secondary o2 sensor cause its not their.
I need a link to something I can buy to either trick the ecu into thinking its their, or some other method advice to get around NYS inspections (legally preferred :D)
Any advice would be much appreciated!
Old Jan 22, 2007 | 09:46 AM
a1320addict's Avatar
Default Re: Inspection time, need some secondary o2 sensor bypass advice (soulrider4ever)
You can do one of two things, I've had success in the past with just hooking up the secondary O2 sensor and wrapping it in tinfoil, it allows the heater of the sensor to think its functioning, but it wont keep the code clear forever, just like 100-200 miles. Or you can make the defouler thingamabob.
Old Jan 22, 2007 | 11:04 AM
itr1244's Avatar
Default Re: Inspection time, need some secondary o2 sensor bypass advice (a1320addict)
your car won't pass the inspection with hondata ecu?
Old Jan 22, 2007 | 11:06 AM
Default Re: Inspection time, need some secondary o2 sensor bypass advice (itr1244)
in NY, they hook up the ecu to their computer which sends info via modem to the dmv. my hondata ecu is obdI, and it expects to see OBDII. So it works til about half way, then locks up and is incomplete.
Old Jan 22, 2007 | 11:11 AM
Type_RS_59's Avatar
Cars that are 10 years old or less need to pass the test in NY. His won't pass because the OBD2 doesn't register on the test equipment.
Old Jan 22, 2007 | 01:16 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">You can do one of two things, I've had success in the past with just hooking up the secondary O2 sensor and wrapping it in tinfoil, it allows the heater of the sensor to think its functioning, but it wont keep the code clear forever, just like 100-200 miles. Or you can make the defouler thingamabob.</TD></TR></TABLE>
worked for me.. ironically cel popped as soon as i left the station..
Old Jan 23, 2007 | 06:44 AM
Black R's Avatar
25 Year Member
I've sold a few 2ndary o2 sensor "foolers" here and locally.
I'm in the process of making one for another user - so if you want one, just lmk.
I usually try to just make them for friends or other itr owners who need to pass emissions with a 'high flow' cat, etc.
Sir001
Engine Management and Tuning
Feb 12, 2017 07:21 AM
jeffy
Mar 21, 2008 02:36 PM
mrduque
May 5, 2004 06:06 PM
thinkbrianthink
Jul 19, 2001 03:59 PM
