Skunk2 stage 1 ?
I am interested to see/hear from those of you running skunk2 stage 1 cams in preferably your b17a, I basically want to see how theese wil react in a sub 10-1 compression motor. I plan to build a 2.0l setup over next winter but I want to see what i can extract from a high mileage but very healthy 9.7-1 b17.
I decided to go with skunk2 stage 1s because A. I figure with my low compression ratio they will end up making more usuable power than other much larger cams and B because I got them for a very good deal from a local h-t member(thanks 00redsir)
I have searched several times and have came up with no dyno plots of b16 or b17s using sks1 in basically bolt on but well tuned motor.
I would love to see some b17 graphs with sks1 or even a b16 hopefully only using pr3 pistons due to the lower compession ratio. or at the very least hear your impressions on your skunk2 stage 1 cams in any motor.
Note : this is not a guess my hp thread, I really want to see the power under the curve and some numbers from successful similar setups.
lopaka07
17
Jul 23, 2005 12:33 AM
JDM2ndGen
Aug 15, 2003 03:59 PM
