d16 dizzy help...please...aghhh
Old Jan 22, 2007 | 08:07 AM
89efDUSTY's Avatar
Default d16 dizzy help...please...aghhh
The problem is i am swapping out my d16a1 from my 89 crx, and putting in a d16a6, but my d16a6 dizzy has no pigtail, wires are cut and the d16a1 dizzy doesn't even come close to matching.I have the female part of the harness on the wiring harness, but i need the male part connecting to the wires on the dizzy. My question is, is there anything I can do to avoid buying a new dizzy, anyway i can swap old pigtail and put wires together "cannot find schematics for the distributors"...thanks
Old Jan 22, 2007 | 08:18 AM
amthompson's Avatar
Go to a junk yard and snag an a6 clip.
Old Jan 22, 2007 | 08:28 AM
89efDUSTY's Avatar
Default Re: (amthompson)
Hahaha tried twice, none...anyone else? please help I need my car so i can get to work and back and not have another employee drive me
Old Jan 22, 2007 | 08:48 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (89efDUSTY)
You have to search my friend......
https://honda-tech.com/zerothread?id=1746889
Old Jan 22, 2007 | 09:05 AM
89efDUSTY's Avatar
Default Re: (goforbroke)
This doesnt help read it...d16a1 has one less sensor...i cannot find the pigtail for it and even if so...i need to know if they will hook up...anyone else, need a schematic not just a picture of wires
Old Jan 22, 2007 | 09:14 AM
goforbroke's Avatar
MEAT PATTY
http://spoonhonda.com/index_mozilla.htm
Go to downloads..........
Old Jan 22, 2007 | 09:17 AM
89efDUSTY's Avatar
Thank you sir. I am downloading it right now...do you know if im a running a D16a1 ECu and the d16a6 has an extra sensor on the clip...will it matter if that sensor is not hooked up because the ECU does not require or recognize that sensor?
Old Jan 22, 2007 | 09:26 AM
89efDUSTY's Avatar
Default Re: d16 dizzy help...please...aghhh (89efDUSTY)
anyone know?
Old Jan 22, 2007 | 09:49 AM
jlicrx's Avatar
the D16A1 distributor has a 5-wire connector like this:
the D16A6 distributor has a 7-wire connector like this:
the 2 extra wires on the A6 are for the Cylinder Sensor which is on the exhaust camshaft on the A1 - you need to take the 2 wires that go to the A1 Cylinder Sensor and put them into the connector for the A6 distributor
the A1 wires are like this:
the A6 wires are like this:
Old Jan 22, 2007 | 09:59 AM
89efDUSTY's Avatar
Default Re: d16 dizzy help...please...aghhh (jlicrx)
Freakin awesome...perfect just what i needed. Does anyone know where to get the pigtail coming from the dizzy to the male harness...my wires were cut, are there any interchangeable harness, or can i cut the female side and just soder the wires...?
Old Jan 22, 2007 | 10:02 AM
jlicrx's Avatar
connector from 88-91 SI, EX or HF or from B18A1 will work - you could splice the wires and solder them, but if you needed to swap distributors, you would have to do it all over again - best to get a connector
Old Jan 22, 2007 | 10:17 AM
89efDUSTY's Avatar
thanks so much
88_hatch_ls
Jul 18, 2013 05:30 PM
revikan
Jan 29, 2008 03:04 PM
WHORE: JDMCoveralls
Jul 8, 2006 07:07 PM
Civic Racer X 7
Jul 23, 2003 01:56 PM
