94-96 Console in a 92??
Old Jan 22, 2007 | 06:53 AM
wxman13's Avatar
Default 94-96 Console in a 92??
Is it possible to convert the console in a 92 Prelude to the 94-96 Prelude console?
Looks like there could be a difference in the parking brake lever? My 92 is a manual transmission Si, 4WS.
Thanks,
Robert
Old Jan 22, 2007 | 07:52 AM
mgags7's Avatar
it is possible, but you will have to change to the later style e-brake handle, rig up the cables to fit, and also make some sort of mount for the new e-brake handle
its a good bit of work, but well worth it, I had a 93 before and hated that console, my 96 lude came with it, a nice (borat accent)
Old Jan 22, 2007 | 10:02 AM
iwubmybb4's Avatar
Default Re: (bb4ever)
yeah! plus you get a cup holder
Old Jan 22, 2007 | 12:34 PM
darkspector2.0's Avatar
i've done it, if you're not good a simple custom fabbing don't do it, or have someone do it for you. I'd give it a 5/10 on the diy scale since you gotta figure out where and how to mount things.
Old Jan 22, 2007 | 04:44 PM
wxman13's Avatar
Default Re: (darkspector2.0)
I feel fairly confident that I can do it, it looks like the most difficult task would be the e brake, does the 94-96 style e brake mount using any of the hole locations from the 92 version, or would I need to drill new mounting holes all together? The newer console looks like it might line up with some of the existing mounting hole locations in my 92? If I could get the mounting brackets from a 94-96 model, it looks like it would make things somewhat easier?
Thanks,
Robert
Old Jan 22, 2007 | 07:25 PM
H20too's Avatar
Default Re: (wxman13)
new holes for the e-brake, plain and simple...
Old Jan 22, 2007 | 07:30 PM
SOHC-VTEC-BB2's Avatar
Default Re: (H20too)
Yup gonna need new hole for the brake - be very carefull and mark everything carefully. Location is very important.
Or just Weld it!!
Old Feb 13, 2007 | 07:20 PM
wxman13's Avatar
Default Re: (LudeFanatic)
I've started looking at what I need to do to get this done, looks like the ebrake cables on my 92 aren't long enough to reach the new location where the 94-96 style ebrake would have to mount? Would I need the ebrake cables from a 94-96 model to make this work?
Old Feb 13, 2007 | 07:31 PM
saikou's Avatar
https://honda-tech.com/zerothread?id=1529665
Old Feb 13, 2007 | 07:36 PM
M2B4's Avatar
Default Re: (saikou)
yeah good bit of fabbing involved. ive got my converion all planned out just havnt had time to do it yet.
Old Feb 16, 2007 | 07:58 AM
wxman13's Avatar
Default Re: 94-96 Console in a 92?? (wxman13)
Have any you guys done this by extending the threaded rod on the ebrake, so it would reach the cables on the 92-93, it looks as though that might be a simpler fix?
Robert
Old Feb 16, 2007 | 10:45 AM
RA102725's Avatar
i woud love the switch to a 94+ console on my 93.. that space is so inefficient stuff falls out of the pocket.. so the same cables can be used?
Old Feb 16, 2007 | 11:51 AM
wxman13's Avatar
Default Re: (mikesta21)
I am in the process of trying to do this, I read in another thread about someone un-bolting the ebrake cables from their 92-93 and pulling enough of them inside the car to connect to the new mounting location for the 94-96 ebrake location, however I'm not real crazy about pulling my cables on my 92, so I'm going to try and extend the threaded rod portion on the 94-96 ebrake handle, by using some 6mm threaded rod cut to length and connecting it using a 6mm connecting nut with thread lock, so it will reach the cable connector for my 92.
Robert
Lutador
Sep 23, 2012 06:32 AM
95SE
Jan 28, 2007 04:27 PM
bb4ninja
Feb 19, 2006 08:13 AM
LilBoi
Apr 6, 2004 12:57 AM
Fly1865
Jul 16, 2002 10:05 PM
