valve upgrade?
If Im going to run the JUN 3's, with Crower springs/retainers, is it necessary to upgrade the valves as well? Or are the stock valves fine for now? I always hear about people getting more aggressive cams and needing the titanium retainers and spring, but I dont hear much about the valves. thanks
what if I raise the rev limit to 10k? Are valves needed then? Obviously Im not going to raise the rev limit just because I got the JUN 3's like some ****** ricer who has no clue, I plan to do it right, just trying to get a good idea what im gonna need. thanks.
that is a question you should ask JUN. I dont think you will make power up to 10k (If and when you do I am pretty sure you would have lighter valves and a different cam setup)
[Modified by t, 4:39 PM 5/16/2002]
