l@@k at those hotties & hoodies
Wow, I never thought this rims are so beautiful, I like this yellow OZ writing on it. This is my *offset test rim* before I go and place an order on expensive Volk TE37's. All my 4 fenders are pulled about 1 inch. I payed 525 USD for the rims and 660 USD for the tires.
Rim specs: OZ F1 Cup in 7.5x16 inch offset 35mm, 44 lbs (20kg) on the scale
damn rubber is kinda heavy, rim is about 10 kg (22lbs), color: anthrazit
Tires: Good Year Eagle F1, 225/45/16, diameter 608mm
Tomorow I'll mount those on my R, cause he is currently at the bodyshop for things like this:
Want to have some cooling effects on my turboed baby, some Mitsu EVO VII hood vents goes in there
[Modified by austrian type-R, 4:34 PM 5/16/2002]
[Modified by austrian type-R, 4:38 PM 5/16/2002]
damn rubber is kinda heavy, rim is about 10 kg (22lbs), color: anthrazitTires: Good Year Eagle F1, 225/45/16, diameter 608mm
One OZ is 10 kg and 1 rubber is 10kg and one Volk is only 5.5 kg
The crazy thing is, that my old 8.5x17 are also 10 kg, but the 225/35/17 rubber is only 8.5 kg. In fact my old setup was lighter.
Weight owns me
[Modified by austrian type-R, 4:41 PM 5/16/2002]
Weight owns me
The rims in my Photoalbum are called CR7 from the company CR Design, Germany.
Yeah, I hate it that the F1 cup are so extremely heavy.
PS: The chicks are in my photoalbum too.
Just a few things, first I could have told you those F1 Cups are heavy, even my old TRM Typhoon 16" rims on my old car were lighter. Also your tires are quite a bit larger than stock diameter. It will hurt your acceleration, you will be travelling faster than indicated on your speedometer, and the tire of course will be quite a bit heavier than a 205/45-16 or 205/50-15 or 215/40-16. I'm guessing you don't have rubbing problems since you had the fenders modified? 225 is pretty wide for an Integra.
Also Hoosiers run very wide for their size.
i have had those wheels on my civic now for almost 4 years now. they have held up great. heavy wheels but great. the color fades after the years on the yellow writing though.
damn, I thought u were gona post pics of hot chicks
wheels look great! and plz post pics of the hood when it´s fitted on, I´ve yet to see a hoodscoop on a DC2 that actually looked good.. although I think this design is in the right direction
power to weight ratio lower than 3 kg per hp
--buji
Yep, correct!
I chosed that tire size for better acceleration 225
I chosed 45 for getting my power better to ground and 45 is better against wheel hooping
I chosed 16, cause of the weight (I'll switch to te'37 in the next month) and the only tire available that comes into mind for me.
I chosed the more diamter rubber for more speed in every gear.
THE NEED, THE NEED OF TOPSPEED ON GERMAN AUTOBAHNS !!!
Ps: I need those rims are heavy before I orderd. This is just an offset and wideness test rim for th Volk.
[Modified by austrian type-R, 6:16 AM 5/17/2002]
please post some pics of the car with the hood on (with the hood scoop) when you get a chance.......i'm very interested in this
y00, I will shot some pics with daddys digicam today when I get the car back from the bodyshop. Come back to H-T about 7 pm
