Possible to clean 90-91 tailights?
Old Jan 21, 2007 | 10:08 PM
DACteg's Avatar
Default Possible to clean 90-91 tailights?
Ok, like most people my tailights over the years it was a daily. Have gotten moisture and kind of a mossy build up inside. Is there any way to disassemble them to clean the plastic at all? i have seen some cleaner at wal-mart but its only for the out side. not sure if you can take these apart.
Thanks fellas
Old Jan 21, 2007 | 10:31 PM
insaneshoota's Avatar
Default Re: Possible to clean 90-91 tailights? (DACteg)
you can pick up after market ones for abit of extra cash im sure.
make your car look a little better to.
Old Jan 22, 2007 | 08:47 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Yes it is VERY possible. There is a castrol product called " Super Clean " I think. Remove the tailights, remove the bulbs of course. Mix the cleaner 1/3 cleaner + 2/3 water. Fill the lights and let them soak. You will also get the nifty pink crap to go clear . Rinse thoroughly and repeat if necessary.
Check out G2IC.com
Old Jan 22, 2007 | 08:51 AM
96 EJ8's Avatar
Default Re: Possible to clean 90-91 tailights? (DAantagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">Yes it is VERY possible. There is a castrol product called " Super Clean " I think. Remove the tailights, remove the bulbs of course. Mix the cleaner 1/3 cleaner + 2/3 water. Fill the lights and let them soak. You will also get the nifty pink crap to go clear . Rinse thoroughly and repeat if necessary.
Check out G2IC.com </TD></TR></TABLE>
yup thats how I did mine and now its red/clear and looks pure secks. I used one called "Mean Green" and it did the same work. G2IC has more info on how to do it.
Old Jan 22, 2007 | 09:49 AM
DA6righthand's Avatar
would anything happen to 94-97 taillights if i did this? like would any of the plastics change or lose their color? i have a leaky taillight gasket and mine are gettin' nasty...
Old Jan 22, 2007 | 11:17 PM
DACteg's Avatar
thanks fellas. And sorry i keep the stock sleeper look and the 90-91 look more like the jdm tails so i didnt want to buy some stock 92-93 ones.
Old Jan 23, 2007 | 08:06 AM
Default Re: Possible to clean 90-91 tailights? (DA6righthand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA6righthand &raquo;</TD></TR><TR><TD CLASS="quote">
would anything happen to 94-97 taillights if i did this? like would any of the plastics change or lose their color? i have a leaky taillight gasket and mine are gettin' nasty...</TD></TR></TABLE>
Just mix it with less cleaner if you want to weaken it. Be careful and do it once or twice to make sure nothing fades. SO FAR mine haven't faded. I've done it twice now once before I realized I needed to replace my tailight gaskets lol.
Chris
dcdude
Mar 16, 2009 10:06 AM
p4eAaLcLe
Honda Motorcycles
Apr 24, 2007 06:11 PM
pinkspider
Mar 2, 2006 11:56 AM
daewonder.
May 27, 2003 08:20 PM
gribbs
26
Apr 19, 2003 11:40 PM
