Front Bumper Removal - 2006 Si
I decided to check and see how hard removing the front bumper might be, in case my mechanics do not want to do the HID installation. I can see the 6 or so screws on the bottom and the 2 on top, but how do I get to the side screws (fender)? Do need to remove the wheels and all the plastic to get to them? Is there anything else I need to look for to get this off?
I searched the site and the net for some type of walk through or instructions on removing the front bumper, but could not find anything.
Any help would be appreciated.
Thanks in advance.
Thanks in advance.
Remove all the pins on the bottom (flathead screwdriver). Remove the screws on the fender wells (phillips). You do not need to take off your wheels. This is very easy to do. Takes less than 5 minutes to remove the bumper once you know where everything is. There are a couple screws holding the grill (which is attached to the bumper). You need an alen wrench for that.
Very easy to put back on as well.
