hankook ventus z212
Old Jan 21, 2007 | 08:26 PM
TokuiAutowerks's Avatar
Default hankook ventus z212
has anyone used these tires before? they are said to be a street/track tire according to the website they any good, bad? better then azenis? im planning on using them for street/track...wanted to get some opinions if any about them before buying them
http://www.hankooktireusa.com/...id=86
Old Jan 21, 2007 | 09:33 PM
DaveSi677's Avatar
Default Re: hankook ventus z212 (TokuiAutowerks)
They are good tires but the Azenis RT-615 are stickier.
The Azenis is the stickiest street tire, in fact its the closest thing to a R compound! The Z212 are not as good as the azenis in the dry but are better in the rain!
Either way if you are looking for a track tire do you really nead wet performance!
Also these tires do not have great tread life. I would go with the Azenis RT-615, you will appreciate it at the track!
Old Jan 21, 2007 | 09:58 PM
vtecsi00's Avatar
i have had both tires and the hankook was pretty comparable to the azenis in dry but not as good but the hankook was definitely much better in the rain
Old Jan 22, 2007 | 07:57 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: hankook ventus z212 (DaveSi677)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveSi677 &raquo;</TD></TR><TR><TD CLASS="quote">They are good tires but the Azenis RT-615 are stickier.
Also these tires do not have great tread life. I would go with the Azenis RT-615, you will appreciate it at the track!</TD></TR></TABLE>
And so does Grassroots Motorsports.
If you ONLY care about dry traction, get the Azenis.
If you also care about wet traction and/or treadlife, you would be better off with the Kumho Ecsta SPT or the Goodyear F1 GS-D3 (both offer excellent wet traction and treadlife; the SPT costs a lot less, while the GS-D3 offers higher performance, wet and dry, than the SPT or the Z212).
Old Jan 22, 2007 | 09:28 AM
efvader's Avatar
Default Re: hankook ventus z212 (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote"> but the hankook was definitely much better in the rain</TD></TR></TABLE>
but overall a very good tire
Old Jan 22, 2007 | 11:40 PM
vtecsi00's Avatar
Default Re: hankook ventus z212 (efvader)
no complaints from me about the hankook's
Old Feb 1, 2007 | 10:25 AM
hybridmoments's Avatar
[QUOTE=DaveSi677]
The Azenis is the stickiest street tire, in fact its the closest thing to a R compound! QUOTE]
that's not quite true
what about Yokohama Advan Neova? 180 treadwear
only thing is it's mostly 17" and 18" sizes
and Pirelli P Zero System. 140 treadwear
and available in a 345/35ZR15 for Lamborghini countach fitment
Old Feb 1, 2007 | 10:39 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: hankook ventus z212 (hybridmoments)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments &raquo;</TD></TR><TR><TD CLASS="quote">that's not quite true</TD></TR></TABLE>
Yes, it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments &raquo;</TD></TR><TR><TD CLASS="quote">what about Yokohama Advan Neova?</TD></TR></TABLE>
Not as sticky. Again, not just my opinion, but also that of Grassroots Motorsports. Did you read their side-by-side comparison test (see link above)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments &raquo;</TD></TR><TR><TD CLASS="quote">only thing is it's mostly 17" and 18" sizes</TD></TR></TABLE>
That too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments &raquo;</TD></TR><TR><TD CLASS="quote">and Pirelli P Zero System.</TD></TR></TABLE>
Not as sticky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments &raquo;</TD></TR><TR><TD CLASS="quote">140 treadwear</TD></TR></TABLE>
Just because a tire has a lower numerical treadwear rating, doesn't mean it's stickier. Especially when another tire (e.g. Azenis) might be labeled with an artificially-high treadwear rating to enable it to be used in certain competition classes which require a treadwear rating of 200 or higher.
Old Feb 1, 2007 | 03:07 PM
HondaF1Fanatic's Avatar
Wear ratings vary widely between manufacturers and even within a brand. Using the treadwear rating is definitely not a good way to gauge tire performance.
Jon
Old Feb 2, 2007 | 10:15 AM
vtecsi00's Avatar
Default Re: (HondaF1Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaF1Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">Wear ratings vary widely between manufacturers and even within a brand. Using the treadwear rating is definitely not a good way to gauge tire performance.
Jon</TD></TR></TABLE>
VERY TRUE.. mot a good way at all
Old Feb 4, 2007 | 11:01 AM
gakkuken's Avatar
there are a lot of comparsion out there for hankook z212 and azenis rt615, and i've used both of these tires for hpde, and i'm sticking to hankook z212!
Old Feb 4, 2007 | 01:49 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: hankook ventus z212 (gakkuken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gakkuken &raquo;</TD></TR><TR><TD CLASS="quote">there are a lot of comparsion out there for hankook z212 and azenis rt615, and i've used both of these tires for hpde, and i'm sticking to hankook z212!</TD></TR></TABLE>
Then you are one of the very, very few. Of everyone I know who has tried both - and I know many such folks - almost all of them prefer the Azenis.
chingchong
Oct 25, 2002 08:52 AM
BoM
Sep 2, 2002 08:02 AM
tygsr
12
Jul 17, 2002 05:59 AM
Petah
Feb 18, 2002 11:42 AM
01CWITR
Jan 5, 2002 06:11 AM
