NT-555R Drag Radial: What tire pressure cold/hot for 1/4 mile runs.
Old May 16, 2002 | 05:21 AM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default NT-555R Drag Radial: What tire pressure cold/hot for 1/4 mile runs.
Are they like slicks that run really low psi, or do you run them like a street tire?
Old May 16, 2002 | 05:23 AM
MPH's Avatar
MPH
New User
Default Re: NT-555R Drag Radial: What tire pressure cold/hot for 1/4 mile runs. (01PYTypeR#1140)
15 to 17 psi
Old May 16, 2002 | 05:27 AM
Default Re: NT-555R Drag Radial: What tire pressure cold/hot for 1/4 mile runs. (MPH)
15 to 17 psi
So they are like slicks! At the strip 25psi would be way to high then?
Flux's Avatar
You need to check out the latest issue of Sports Compact Car - they review a few tires on a drag strip (a slick, BFG g-Force Drag Radial, and Azenis). They go over tire characteristics and performance at various tire pressures...
I know it doesn't apply exactly to your question, but they found that the Drag Radials ran best at about 14-16 psi...
[Modified by Flux, 8:28 AM 5/16/2002]
Old May 16, 2002 | 05:30 AM
I thought they would be like the Azenis tire, where 30psi gives you the full contact patch, and lowering the pressure that low on the NT-555R would cause them to ride on the edges giving you much less traction.
Old May 16, 2002 | 05:36 AM
MPH's Avatar
MPH
New User
15 to 17 psi
25psi is to high. Try 15psi and warm them up a little. Oh and they are nothing like slicks.
Old May 16, 2002 | 05:38 AM
BryanSprinkel's Avatar
I used them at 22psi and was able to pull a best 2.05 60foot time. Mostly 2.1's
edit: I would spin them to get rocks off, but no burn outs.
[Modified by BryanSprinkel, 9:42 AM 5/16/2002]
Old May 16, 2002 | 05:41 AM
Default Re: NT-555R Drag Radial: What tire pressure cold/hot for 1/4 mile runs. (BryanSprinkel)
were these pressures with the NT-555R Drag Radial?
Old May 16, 2002 | 05:44 AM
Yes, with the 555r. With a stock car + JDM header, and cat. All interior, and belts were on the car.
Old May 16, 2002 | 05:45 AM
Back in Black's Avatar
Rather OG
Hehe...you drag ricer
Old May 16, 2002 | 05:50 AM
Default Re: NT-555R Drag Radial: What tire pressure cold/hot for 1/4 mile runs. (Vader in NC)
Drag racing 0wnz you Vader, you're just mad because you suck at it
Old May 16, 2002 | 05:59 AM
Rather OG
At least I know how to turn, 10-boy!
Old May 16, 2002 | 06:33 AM
Johnny Tran's Avatar
Yes, with the 555r. .
cheater....i ran faster than that in a civic with crappy street tires f00 i own your arr (in a strait line)
Old May 16, 2002 | 06:54 AM
Default Re: NT-555R Drag Radial: What tire pressure cold/hot for 1/4 mile runs. (Johnny Tran)
This Question isn't for me it's for a friend with a GSR, although I hear the Azenis is just as good as drag radials in a 1/4 mile run, maybe not as consistant.
Old May 16, 2002 | 07:00 AM
You just 0wned youself, strait line *****.
Old May 16, 2002 | 07:03 AM
thats it, im putting BUSLENGTHS on j00r azz at VIR in june
Old May 16, 2002 | 07:33 AM
AllMotorMadness's Avatar
15psi should be pefect on a hot day
accord99power
May 27, 2009 03:17 PM
crazy_ls_90
Aug 25, 2008 04:50 PM
cbustuner
Aug 16, 2008 09:23 PM
dragaholic
Nov 19, 2006 02:57 PM
itr501
Jun 11, 2002 12:54 PM
