How much bigger are your primaries vs the ports size?
Old Jan 21, 2007 | 06:07 PM
MidShipCivic's Avatar
Default How much bigger are your primaries vs the ports size?
I have a V8 Turbo manifold I'm putting together, the ports are roughly 50mm wide and 31.95MM high Which makes them oval. I was thinking about 2'' round primarys but slightly crushing the tubing to match the port shape at the flange.
Does 2'' sound crazy ? Or am I thinking too much which I probably am because the tubing after the oem header is 2'' wide 50mm and 30mm 1.2'' high.
Old Jan 21, 2007 | 06:59 PM
Default Re: How much bigger are your primaries vs the ports size? (.EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">
If you convert the oval port to a circle:
(50 + 32) / 2 = 41mm = 1.61"
That's the exact pipe diameter you'd need to fit the port. The nearest up-size you'll find is 1.75" which is what I'd go with.</TD></TR></TABLE>
Thanks alot. The 5L engine is goinna see a GT4718 theres gonna be some trial and error along the way.
HotboxedTypeR
Jun 27, 2008 01:59 PM
LoganMantits
Apr 28, 2005 05:58 PM
DeLiRiOu5
Honda Motorcycles
Mar 3, 2005 07:25 PM
Garrett
Jan 18, 2004 11:07 AM
Luke
Dec 20, 2003 06:43 AM
