Civic ek Coupe Under My hood , help
Old Jan 21, 2007 | 02:11 PM
Flash!i!Civic's Avatar
Default Civic ek Coupe Under My hood , help
Hey can any 1 recommemd any changes 2 my ek , that are not engine lifts lol or Turbo ? LOL ( engine Mods )
-Car Spec-
Under The Hood
1.6i LS SOHC ( might have High lift cams soon )
AEM Long Arm Cold Intake
Megan Raceings Stainless ST 316 Grade 4-2-1 Branch
Manifold De-cat fully Custom Stainless Exhaust System
NGK Spark-Plugs Gold Plated Terminals
Clutch & GearBox
XTD Stage One Clutch
Annodised Short Shifter Type-R Chrome ****
Modified by Flash!i!Civic at 5:47 PM 1/22/2007
Old Jan 21, 2007 | 02:54 PM
vtec4lyfe's Avatar
do your entire valve train
valve retainers
valve springs
compression valves
cams
adjustable cam gears
head and main studs
retainers
sleeves
the whole meal deal
Old Jan 21, 2007 | 03:23 PM
Syndacate's Avatar
What does all the things you listed (except "Under The Hood") have to do with engine mods? Just extra stuff for people to sift through, might as well get rid of them as they're redundant and unimportant.
So you don't want to swap, and you don't want to boost.
So uhh...what's your budget?
Old Jan 21, 2007 | 03:30 PM
Turbo_y8's Avatar
Default Re: (Syndacate)
go from 17" rims down to 15" rims take the extra cash and buy a intake manifold and has it port matched to your head!
Old Jan 22, 2007 | 08:54 AM
Default Re: (Turbo_y8)
Its not that i dont want to lift the Engine , or Turbo it , thats just the 2 most Commin things u can do and wanted 2 no wot other ppl said b4 i slam a turbo in it , cash aint an issue its a project for me realy
Old Jan 22, 2007 | 09:10 AM
CRX T-Si's Avatar
Default Re: Civic ek Coupe Under My hood , help (Flash!i!Civic)
Get yourself a nice suspension set-up with front and rear sway bars. A powerful car without suspension ain't going no where fast.
Then when you have enough money work on the engine.
That's my $0.02.
Old Jan 22, 2007 | 09:17 AM
Iboot's Avatar
wow use the search button. Here is a link from the Prelude section on N/A. The parts he may talk about are different than the Civic parts but the Idea stays the same. enjoy https://honda-tech.com/zerothread?id=180883
Old Jan 22, 2007 | 09:37 AM
smileycvc's Avatar
Default Re: (Iboot)
I guess you could do a wiretuck or something. A least it would be a clean single cam
Old Jan 22, 2007 | 09:39 AM
Syndacate's Avatar
Default Re: (Iboot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iboot &raquo;</TD></TR><TR><TD CLASS="quote">wow use the search button. Here is a link from the Prelude section on N/A. The parts he may talk about are different than the Civic parts but the Idea stays the same. enjoy https://honda-tech.com/zerothread?id=180883</TD></TR></TABLE>
No they don't. A 2.2L DOHC responds a lot better to bolt-ons than a 1.6L SOHC.
Old Jan 22, 2007 | 09:48 AM
CRX T-Si's Avatar
Default Re: (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">I guess you could do a wiretuck or something. A least it would be a clean single cam</TD></TR></TABLE>
I think he was leaning more towards performance and not looks at this moment.
Old Jan 22, 2007 | 10:31 AM
EJgsr's Avatar
Old Jan 22, 2007 | 01:46 PM
Default Re: Civic ek Coupe Under My hood , help (CRX T-Si)
suspension , i have 100MM Coilovers sitin at 85 mm all round
Old Jan 22, 2007 | 01:56 PM
This is a link 2 my Civic , it duz 140mph and off the clock with the mods thats in it , So for a (NON V-tec) u think thats good ? my civic smoke`s the **** out my m8s CRX del-sol V-tec DOHC makes his look like a 1.4 lol let me no
https://honda-tech.com/gara...=6020
Modified by Flash!i!Civic at 11:10 PM 1/22/2007
Modified by Flash!i!Civic at 9:00 PM 1/23/2007
Old Jan 22, 2007 | 02:29 PM
SiREJ8's Avatar
i dont know what models you have but find a hydro trans from a 1.6l vtec, the engines are a z6 or y8 in the us! the trans has shorter gearing and will help out... d15b trannys are similar also!
Old Jan 23, 2007 | 04:40 AM
Iboot's Avatar
doesn't sound like he wants to rebuild his engine completely, so bolt-ons is his only way.
Old Jan 23, 2007 | 07:10 AM
Budget EJ's Avatar
Default Re: (Iboot)
How about you learn how to type and then come back to this forum. I got a headache trying to reed wut u rote.
Old Jan 23, 2007 | 11:59 AM
Default Re: (Budget EJ)
there is a Difference Between Learning how 2 type & a spelling mistake !!!
Old Jan 23, 2007 | 12:17 PM
Default Re: (Iboot)
well i am glad u guys gave me ideas , I think i am going to skim my head port n polish , do my cams valve retainers valve springs Etc. Then start puting Bolt ons in , so any 1 got any bolt ons they swear by ? and Recommend
das_thunder
Jul 4, 2011 05:25 PM
xpsonic
Feb 15, 2005 06:11 PM
