Honda S2000 Honda S2000
le axle spacers
Old Jan 21, 2007 | 01:56 PM
s2pie's Avatar
Default le axle spacers
i need some axle spacers for my 03 s2k... any info would help
Old Jan 21, 2007 | 02:10 PM
silentdancer's Avatar
Default Re: le axle spacers (s2pie)
no.
Default Re: le axle spacers (silentdancer)
http://www.bulletproofautomotive.com
look for the j's racing half shaft spacers
Old Jan 21, 2007 | 03:44 PM
s2pie's Avatar
thanks bro i heard about your car... how is it doin
Old Jan 21, 2007 | 03:52 PM
its fixed just waiting on my new rims, then ill be back in the game
Old Jan 21, 2007 | 04:49 PM
LAS2K's Avatar
j's are overrated and too expensive. try motorklasse half shaft spacers. i think they're about half the price and do the same job.
Old Jan 21, 2007 | 05:26 PM
hondaek96's Avatar
j's are 10mm, compared to Motorklasse's 7.5mm, and about a $50 difference between both. Go with motorklasse if you might put the car back to stock height. they dont need to be removed, however j's does. Also in spring, T1R is coming out with their 2 piece spacers that are 10mm, and are alot easier to install, dont need to remove the driveshaft
Old Jan 21, 2007 | 06:47 PM
LAS2K's Avatar
Default Re: (hondaek96)
why do you need 20mm total spacing? ap2 lengthened it to 5mm a side IIRC for a total of 10mm. why would you need another 5mm total over the motorklasse?
Old Jan 21, 2007 | 09:47 PM
hondaek96's Avatar
Default Re: (LAS2K)
this is what j's racing claims....The original driveshafts of the S2000 is design at the stock ride height so when the car is lowered with coil springs or coil-over suspension then the driveshafts will be stretched about 10mm each side. This will occur a lot of stress to the driveshaft. As a result, the driveshaft will wear down in a very short period of time. J's Racing offer this spacer which the driveshaft can be 10mm closer to the outter side of the shaft so the shaft will not be stretched. This also allows the driveshafts to have longer life.
they made it for a reason at ten. and motorklasse did it at 7.5 so you can put the car back to stock.....and they claim only for the ap1,
since honda has extended the diff joint on the ap2
Old Jan 21, 2007 | 10:06 PM
LAS2K's Avatar
if you are lowered over an inch than yes do get the spacers. anything at or under you are a.o.k.
Old Jan 22, 2007 | 08:16 PM
streetsold6teeny8's Avatar
so then for my ap2 i dont need spacers if I use springs???
Old Jan 22, 2007 | 08:46 PM
LAS2K's Avatar
Default Re: (streetsold6teeny8)
correct.
Old Jan 23, 2007 | 05:44 AM
s2pie's Avatar
Default Re: (LAS2K)
thanks for all the input guys... so would the J's be a better fit
Old Jan 23, 2007 | 09:12 AM
all that j's stuff is expensive up the ***
Old Jan 23, 2007 | 12:34 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (s2pie)
sTEVE I ALREADY LINKED YOU! THATS THE CHEAPEST YOU WILL SEE OUT THERE... WITH THE J'D BEING AT 10MM U HAVE TO REMOVE IT IF THE CAR IS RAISED BACK UP
ExpeditiousRacing
Honda CR-V & Element
Feb 25, 2011 02:28 PM
kroze
Transmission & Drivetrain
10
Jul 7, 2009 02:09 PM
Hoppa
Dec 5, 2006 08:51 AM
jacoop86
Aug 11, 2006 04:07 PM
