mini me obd help...my fist time on this site
Old Jan 21, 2007 | 01:49 PM
progfool's Avatar
Default mini me obd help...my fist time on this site
i have an 89 crx with a d15 dpfi so far i got the following for a mini me swap.
d16z6 head with intake and vtec solenoid
d16z6 timing belt
adjustable cam gear
d16y8 head gasket
p28 virgin ecu
dist. out of an 88 hf wich i also own but needs a motor
my problems are that i have been searching for the wiring diagrams and cant find 2 that match and i am really confused on how to convert to obd1. i want to use the dx harness and do the necesary wiring mods.but every site i go on does'nt say p28 it says p06 or p13 or another.will the p28 plug right into my obd0 harness?and if not what do i gotta do. thanks
Old Jan 21, 2007 | 01:51 PM
AJxr's Avatar
Default Re: mini me obd help...my fist time on this site (progfool)
youll need an obd1 distributor, obd1 conversion harness, and no the p28 wont plug in without the harness.
now look up info on what i told you and your set.
Old Jan 21, 2007 | 01:52 PM
progfool's Avatar
Default Re: mini me obd help...my fist time on this site (AJxr)
thanks..will the hf dist work or will i need a diff. one
and how do i wire it under the hood.
they show 2 different harnesses which 1 do i need?
http://motors.search.ebay.com/...mZR40
Modified by progfool at 3:03 PM 1/21/2007
Modified by progfool at 3:41 PM 1/21/2007
Old Jan 21, 2007 | 04:19 PM
amthompson's Avatar
no, the hf dizzy wont work for an obd1 setup, you need an obd1 distributor. go to http://www.rywire.com for the conversion harness.
Im pretty sure you'll have to cut the clip off of your engine harness for the dizzy and wire up a plug for an obd1 dizzy.
Old Jan 21, 2007 | 04:49 PM
progfool's Avatar
Default Re: (amthompson)
thank you...you guys are great.
Old Mar 14, 2010 | 05:08 PM
89crex206's Avatar
TRIAL USER
im havin the same problem i have a 89 crx dx with a d16y8 swap im using the stock harness off of the y8 motor its not plugin in to the stock harness to the car so havin a tough time figuring out the wiring and wat to do can anybody help me out?
Old Mar 14, 2010 | 07:05 PM
projekt90ef's Avatar
3+ year old thread youre replying to...post a new thread and dont ressurect the dead homie
90civicbns
Jun 26, 2013 10:59 AM
Ride1226
May 15, 2012 04:54 PM
Hondamonster
May 31, 2007 11:07 AM
hondaman156
10
Nov 14, 2006 08:57 AM
Mark80
Oct 1, 2006 11:55 AM
