Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Honda crv. cold start
Old Jan 21, 2007 | 12:51 PM
Dznutz13's Avatar
Default Honda crv. cold start
In the morning when i start my 2001 crv i need to warm it up or it will shut off on me when i put it into drive the check engine light goes on every once in a while i changed the fuel filter and i cleaned the throttle body. any help would be good thx
Old Jan 21, 2007 | 06:39 PM
golf's Avatar
Default Re: Honda crv. cold start (Dznutz13)
You should start by getting the DTC code since your CEL is coming on. This will be a start as to what the problem is.
Old Jan 24, 2007 | 06:51 PM
Dznutz13's Avatar
The check engine light isnt on ne more but still having cold start problem. since the cel isnt on the code reader wont read ne thing.
Old Jan 27, 2007 | 12:25 PM
ecu_fix's Avatar
Even if the CEL is not on you should be able to get History codes.
If none, go tolive data and check coolant temperature sensor reading, TPS and once warm O2 sensor.
chubs93
Jan 29, 2012 03:37 PM
SoCal07Si
12
Apr 25, 2011 10:54 AM
aje151
Feb 6, 2011 07:03 AM
Shade93
16
Oct 19, 2010 09:29 PM
bstaralways
Sep 4, 2007 02:51 PM
