how high are you revving on your oem retainers?
Old Jan 21, 2007 | 08:54 AM
blackeg's Avatar
Default how high are you revving on your oem retainers?
ok im stuck, i dont know if i should go with aftermarket ti retainers or not. heres my stance:
1) i dont feel like taking my motor apart every 10k miles to replace them. i drive over that each year and im trying to make a build that i can leave alone for a few years. are there any snap fit (or press fit whatever) ti retainers that have been proven to last like 20-30k miles?
2) im using itr springs and gsr cams, and would like to take my car to 8500 i think. i have heard some bad stories about oe retainers having some probs above then, but im still not sure. ive also seen/heard about the keepers pulling through the retainers, which i am scared of.
cliffs notes:
can i safely run a 400+ hp motor to 8500 rpms on oem b16 retainers for like 20-30k miles? if not, what ti retainers offer the longest lifespan? i have a set of portflows now but they have about 9-10k miles on them and im very hesitant to use again.
Old Jan 21, 2007 | 09:10 AM
narfdanarf's Avatar
Default Re: how high are you revving on your oem retainers? (blackeg)
my cousin's civic 450whp, GSR cams, Crower spings, oem retainers (100kmiles or so) and 9k rpm for like 15,000 miles I think so far.
Old Jan 21, 2007 | 10:04 AM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">ok im stuck, i dont know if i should go with aftermarket ti retainers or not. heres my stance:
cliffs notes:
can i safely run a 400+ hp motor to 8500 rpms on oem b16 retainers for like 20-30k miles? if not, what ti retainers offer the longest lifespan? i have a set of portflows now but they have about 9-10k miles on them and im very hesitant to use again.</TD></TR></TABLE>
the stock rev limit is 8200, 300more rpms im sure isnt goint to hurt it. i know of alot of people who rev there stock B series vtec motors to 8500 (including me) without a problem. i think keepers pulling through is a result of too high of a lift on the cams for the stock valvetrain.
Old Jan 21, 2007 | 10:27 AM
a1320addict's Avatar
Default Re: how high are you revving on your oem retainers? (CoreyR)
My motor sees 8700 at the track, 8300 on the street. Stock
Old Jan 21, 2007 | 10:36 AM
s2kdre's Avatar
Default Re: how high are you revving on your oem retainers? (a1320addict)
my friend used oem type r valvetrain and reved to 10k all day and never dropped a valve, some can take it and some cant.
Old Jan 21, 2007 | 05:41 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">My motor sees 8700 at the track, 8300 on the street. Stock </TD></TR></TABLE>
thats just about exactly what i was looking for.
again my valvetrain will consist of gsr cams/skunk gears. oem itr dual springs and b16 retainers/keepers/valves. the b16 parts have about 50k miles, not sure on the itr springs but they are in good visual condition..
Old Jan 21, 2007 | 05:51 PM
zexxbo's Avatar
if you dont want to hassle or worry, just pick up some skunk2 retainers. i had a friend that was revving to 8700 on stock in his b16 and he floated some valves. i went with a full skunk2 valvetrain. if you want to worry even less, get the ferrea
Old Jan 21, 2007 | 08:55 PM
Wickedsol94's Avatar
Stock B16A Sir-II 8200stock
I rev to 8400 daily, and im confident it can hold more on the b16 valvetrain. ITR springs/retainers would last the lifetime of the motor and could handle 8800rpm im guessing.
Old Jan 21, 2007 | 09:01 PM
92redhatch's Avatar
ive had my rev retainers for over 2 years ( 25K+ miles) with no problems. and i rev 9500rpm on my turbo b16.
Old Jan 21, 2007 | 09:35 PM
riceball777's Avatar
stock retainers are weak get ti retainers
stock retainer breaks in half
drops valve
Old Jan 22, 2007 | 02:12 AM
blackeg's Avatar
Default Re: how high are you revving on your oem retainers? (riceball777)
^^^^ see thats what im trying to avoid on a built sleeved motor. i dont have money to totally rebuild everything again...
Old Jan 22, 2007 | 03:55 AM
quicksol95's Avatar
my buddy had a stock type-r motor drop a valve at 9200rpms
Old Jan 22, 2007 | 05:30 AM
TODAwhore's Avatar
Default Re: how high are you revving on your oem retainers? (quicksol95)
Port Flow's here about 50k on them still look great...with a good bit of track time.
Old Jan 22, 2007 | 02:44 PM
blackeg's Avatar
Default Re: how high are you revving on your oem retainers? (TODAwhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAwhore &raquo;</TD></TR><TR><TD CLASS="quote">Port Flow's here about 50k on them still look great...with a good bit of track time. </TD></TR></TABLE>
have many other people put that many miles on portflows??? ive got a set with about 9-10k on them now. visually they look real good. maybe ill get in touch with portflow and see what kind of thickness they should be at and ill compare mine to see how worn down they are
Old Jan 22, 2007 | 02:54 PM
92redhatch's Avatar
dont go with oem.
Old Jan 22, 2007 | 04:51 PM
88sleeperx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">^^^^ see thats what im trying to avoid on a built sleeved motor. i dont have money to totally rebuild everything again...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">if you dont want to hassle or worry, just pick up some skunk2 retainers. if you want to worry even less, get the ferrea</TD></TR></TABLE>
Old Jan 23, 2007 | 07:03 AM
nasteboyii's Avatar
I ran NA for a few years w/crower stg 2 cams and crower springs, stock OEM retainers (retainers had over 100k miles on them) slapped a turbo setup made well over 400hp on that setup with 9500 rpm shifts, NO PROBLEMS&lt; then finally this year i swapped over to titainium retainers, so it can be done
but again if u have lots of money in your motor i wouldnt take the chance, its your call
dan
Old Jan 24, 2007 | 02:18 AM
blackeg's Avatar
Default Re: how high are you revving on your oem retainers? (nasteboyii)
i do have enough money in my motor, and enough in my pocket to get some ti retainters.
so whats the agreement on brand? id want something thats press/snap fit so they do not wear as fast
Old Jan 24, 2007 | 05:50 AM
92redhatch's Avatar
REV retainers ftw.
Old Jan 24, 2007 | 07:58 AM
turbotime's Avatar
i run omnis with their springs and lovem
Old Jan 24, 2007 | 10:10 AM
ExVtec's Avatar
Default Re: how high are you revving on your oem retainers? (narfdanarf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narfdanarf &raquo;</TD></TR><TR><TD CLASS="quote">my cousin's civic 450whp, GSR cams, Crower spings, oem retainers (100kmiles or so) and 9k rpm for like 15,000 miles I think so far.</TD></TR></TABLE>
I'm that cousin.
So far so good. 8k on the street 9k on the dyno/track.
Fingers crossed...however I think this winter I am going to replace the retainters..for piece of mind...
Old Jan 24, 2007 | 10:24 AM
92redhatch's Avatar
Honda retainers were not made to rev that high. So if you want to take a risk then go ahead but for $140 you can buy retainers and not have to worry about droping a valve.
Old Jan 24, 2007 | 10:37 AM
22_42r_eg's Avatar
if u really tryin to stay away from problems down the road, then why would u question using aftermarket retainers...just my opinion
Old Jan 24, 2007 | 10:38 AM
redex04's Avatar
Default Re: (92redhatch)
where can u get ti retainers for 140?
Old Jan 24, 2007 | 10:39 AM
Toda Party's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">Honda retainers were not made to rev that high. So if you want to take a risk then go ahead but for $140 you can buy retainers and not have to worry about droping a valve.</TD></TR></TABLE>
original post said 8,500
OEM ITR revs to 8,400 / 8,600 fuel cut
so..........
i feel: rev to stock or barely over "stock" OEM is fine
u want 9,500-10k+ then that's asking a bit much of OEM
