New Build 6.5cubes 18" sub 6" PSP Ports Hatchback 56kNO
Old Jan 21, 2007 | 08:39 AM
shyboy817's Avatar
Default New Build 6.5cubes 18" sub 6" PSP Ports Hatchback 56kNO
Well since this forum doesn't move much. I decided to entertain all the fellow audio/security/video sections with some pictures of my new build. Hope you enjoy.
The beginning... I fit 2 x 4x8 and 1 x 4x8 piece of wood in my Integra Hatchback. A few cuts and I was good to go.
MDF
After some measuring, cutting down the pieces into the right sizes. We are finally starting. But first, I needed a new false floor.
How it actually looks without false floor and with rear seats (I have rear false floor but it was crapppy), BEFOR.
The aftermath, after some hit and miss cuts and measuring.
Well enough with the trunk. Lets get on with the build!
Putting the pieces together, glued/clamped and brad nailed ftw.
Got 4 pieces put to gether for half the box and decided to throw it inside the car to see how it looked and how big it was.
Finally got the box together and baffle on. Clamping for glue to dry. Might look ugly right now but it'll look better.
Got the big *** hole cut. I didn't expect the hole to be this big. Double Baffle FTMFW.
Finally got my Terminal cut, and mounted for temp until I get home and solder on the wires and glue it and screw it on.
Onto the bracing.
Started to cut the holes for the 1 1/4" Oak Wooden Dowels. (HD biggest one, and Hardwood and Oak Wood, the hardwood one was weak)
Cut the dowel in half and used it as 2.
Edges rounded up. Still needs touch up but it'll do.
Box finished and in the trunk
Ah how could I forget to post the updates here.
Updated pictures with the ports on (tubes not on). Just to see what they look like on.
I also may have a problem. The basket might hit the ports but i'm not sure. It's REAL REAL REAL close. Only time will tell when my new recone comes in.
Update:
Well I finally got the recone and everything. I checked to see if it fit, and it clears no problem! *WHEW*. Here are the updated pictures of the recone.
The FI Recone package
Basket/Softparts
Blank Dustcap
RE XXX Dustcap
Test fitted in the box (the sub is now fully assembled/reconed, just put it together and threw it in the box for the pic)
Comments/Questions/Suggestions welcome.
Modified by shyboy817 at 8:51 AM 1/26/2007
Old Jan 21, 2007 | 11:41 AM
skingfreak's Avatar
Default Re: New Build 6.5cubes 18" sub 6" PSP Ports Hatchback 56kNO (shyboy817)
wow that looks sweet. what was the total time invested?
what kind of sub are you planning on putting in it?
i hope you dynomated the crap out of your car
Old Jan 21, 2007 | 12:35 PM
shyboy817's Avatar
Took like 13hours on/off to build the box/false floor. Started Saturday Noon finished around 1am or so. 18" 2005 RE Audio XXX / FI Audio Softparts Dual1.
Old Jan 21, 2007 | 12:48 PM
skingfreak's Avatar
Default Re: (shyboy817)
dang, that thing is going to hit. are you doing this for DB drags, or just personal use. or kinda both?
Old Jan 21, 2007 | 01:00 PM
shyboy817's Avatar
It's for daily driver use. So basically personally use. But I do want it to hit high numbers on the termlab also.
Old Jan 21, 2007 | 04:01 PM
RICO_'s Avatar
NO MERCY!
Overkill anyone?? That's gonna be a monster. And in a hatch to. eeek!
Old Jan 21, 2007 | 04:09 PM
shyboy817's Avatar
What can I say. I like it loud
Old Jan 21, 2007 | 06:35 PM
skingfreak's Avatar
loud you shall get roflma. what did you have in there before?
Old Jan 21, 2007 | 07:38 PM
shyboy817's Avatar
Same sub, except it was a 12"
Old Jan 21, 2007 | 07:50 PM
bpr0422's Avatar
Whats up with the camera?
dirty lenses or is it raining/snowing where you are?
Old Jan 21, 2007 | 09:40 PM
shyboy817's Avatar
I was using my phone for the camera. The lens kept getting sawdust on em and crap.
Old Jan 22, 2007 | 01:23 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
bass head
Old Jan 22, 2007 | 08:03 AM
xrccrx's Avatar
Default Re: (wrx-killer-Sti eater)
IA 20.1, nice amp, i have 2 and i also have a 40.1
Old Jan 22, 2007 | 08:15 AM
8520's Avatar
bass monkey
Old Jan 23, 2007 | 10:36 PM
Jose-aka-Pedro's Avatar
Default Re: (misanthropist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist &raquo;</TD></TR><TR><TD CLASS="quote">bass monkey</TD></TR></TABLE>
made me laugh.
*goes to listen to song*
Old Jan 24, 2007 | 08:48 AM
mhart's Avatar
that's really nice.
Old Jan 26, 2007 | 05:51 AM
shyboy817's Avatar
New pictures on top if anyone cares for the build update.
Old Jan 26, 2007 | 06:57 AM
skingfreak's Avatar
that looks awesome. when how long till you have it finished in the car?
Old Jan 26, 2007 | 07:27 AM
shyboy817's Avatar
Well i'm taking the box to get it line-x'd soon, either today/tomorrow. I'm having it hooked up this weekend most likely.
Old Jan 26, 2007 | 08:42 AM
skingfreak's Avatar
cool cool, def post up some pics of the final product. im surious to see how it looks.
Old Jan 26, 2007 | 10:56 AM
hybridzOr's Avatar
Default Re: (skingfreak)
RE FTmfW
&lt; I got two re mt 18's just sitting around.... need to sell.....
Old Jan 29, 2007 | 09:22 AM
shyboy817's Avatar
Not sure if anyone still looks on here. But here's an update. Got the box sprayed. Got the recone done. Got the battery. Amp gain turned down.
On with the pictures...
Textured of the box
Rear of box
Box in trunk
Another
The HC2400
Sitting at a steady 12.8volts
12" basket vs 18" basket during recone
18" Basket
18" 05 RE XXX motor / FI Car Audio Softparts recone
Old Jan 29, 2007 | 09:32 AM
8520's Avatar
Holy **** that's huge. Ports are going to be firing towards the front or the back?
for updates.
Old Jan 29, 2007 | 09:37 AM
shyboy817's Avatar
Ports firing towards rear of the car.
Old Jan 29, 2007 | 11:19 AM
turbosi03's Avatar
The box looks really good
only thing I see hurting the effeciency of your enclosure is having the ports too close to the rear. It will probably change the ports tuning as well, but I'm sure it will still be lould with that monster sub.
