integra brakes onto eg....small rim
i've been searching for a while and havent really found a true answer. im running a set of steelies on my 93 eg and i believe they're 13s. im going to be purchasing a set of 94 ls integra brakes for 200 bucks (with everything...not that i know what everything is exactly). and i've heard that i may have to grind the calipers to make it fit. any truth is this? cause ive also read that they would fit perfectly....so im a little unsure about this
if the '94 ls calipers are bigger (im not sure if these are even the same as the gsr calipers) then you need 14" steelies, and the hx wheels do not fit either.(unless you grind the caliper)
Modified by cxSHOE at 9:55 AM 1/21/2007
all integra calipers are the same (minus itr)
Youre going to need at least 14" wheels with a 5mm spacer (or you can grind the caliper a bit). I run teg calipers with 14" wheels in the winter, and there is barely enough clearance as it is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">all integra calipers are the same (minus itr)
all years?
all years?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">
all years?</TD></TR></TABLE>
90-93 are the same, 94-01 are the same
tofu man
Feb 18, 2007 07:59 PM
JDM Civic Hatch
Nov 21, 2003 04:59 PM
