z6 into ek swap, need distributor help from the sohc guys
Old Jan 21, 2007 | 08:12 AM
soHybridized's Avatar
Default z6 into ek swap, need distributor help from the sohc guys
I want to pull the y8 from my 98 ex and put in my built z6 and tuned p28 ecu. After searching it looks like I'll need an obd2a-obd1 ecu conversion harness. I'll need to adapt the injector plugs on the ek harness to fit the dsm injectors on my z6 and i'll need to swap over the alternator from the y8.
Now what I'm not sure about is the distributor difference. Can I use the y8 distributor on the z6 head or do i need to rewire the z6 distributor to work? I think the slot on the y8 cams are degreed differently so I have a feeling I can't swap the dizzys. Thanks for any help.
Old Jan 21, 2007 | 08:32 AM
sohcvtec1995's Avatar
yea the mounting locattion of the mounting is different, aswell as the plugs. i believe you have to use the dizzy that is for the head, and rewire it the correct obd.
Accord9422
Mar 10, 2012 01:51 PM
EJAYATE
Nov 22, 2010 10:16 AM
91integraLSVTEC
Sep 14, 2007 01:02 PM
94dxt
Dec 26, 2003 08:49 PM
