Wrong Spark Plugs???!?!
Old May 15, 2002 | 11:42 PM
00ek9's Avatar
Default Wrong Spark Plugs???!?!
I just changed out my spark plugs with some NGKs....I got some Civic Si ones cuz they ran out for GSR or type R. My friend told me that Civic Si ones are the same. But now i got a check engine light.... Okay guys..
MY question is are they the same?! if no are gsr same with the type r????
Old May 15, 2002 | 11:47 PM
TypeR_853's Avatar
Default Re: Wrong Spark Plugs???!?! (18c5cx)
nope...they're not the same at all. one important detail is the gap and level of the plug...the ITR's is very specific!!! wise bet is to exchange them for the right ones...most likely will solve your problem stick with the ngk platinums though...don't get persuaded by all the iridium hype.
Old May 15, 2002 | 11:50 PM
00ek9's Avatar
Default Re: Wrong Spark Plugs???!?! (TypeR_853)
whats the gap? 0.4?
Old May 16, 2002 | 12:14 AM
TypeR_853's Avatar
here's the spark plug spec for ITR's:
NGK PFR6G-11
Gap: 0.043in
hope that helps
Old May 16, 2002 | 12:20 AM
spoon_ek9's Avatar
i think the gap should be same for all b-series honda(1.1mm?), but different in heat range. anyway, check whats the code.
Old May 16, 2002 | 12:27 AM
TypeR_853's Avatar
Default Re: Wrong Spark Plugs???!?! (spoon_ek9)
nope the GSR actually has a different gap i believe it's 1.3mm or .051in, while the ITR is 1.1mm or .043in
Old May 16, 2002 | 12:36 AM
spoon_ek9's Avatar
then i dunno, since the service manual from honda said the spark plug for sohc and dohc have the same gap 1.1mm, so i assume all the honda should have the same gap
Old May 16, 2002 | 01:23 PM
t's Avatar
t
What is the code? Are you sure you didnt mix up the wires?
Old May 16, 2002 | 01:41 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Wrong Spark Plugs???!?! (t)
That's what I was thinking. I highly doubt that having the wrong gap or the wrong heat range would throw a code. It might cause misfiring or detonation, niether of which throw codes.
Old May 16, 2002 | 03:43 PM
t's Avatar
t
Default Re: Wrong Spark Plugs???!?! (newt2)
... It might cause misfiring or detonation, niether of which throw codes.
Actually 71,72,73, 74 is misfire codes.
Old May 16, 2002 | 04:56 PM
JSIR's Avatar
New User
the owner's manual is a bit misleading on Civics, cause the the SOHC's use 1.1mm copper plugs that you gap yourself, so the manual lists the gap at 1.1mm. It doesn't list the gap for DOHC 1.6 vtec cause they assume you are using factory plat. plug which comes pre-gapped at 1.3mm and don't assume to be changed for 100,000 miles., so they don't really get into the DOHC gap info very clearly. But the GSR and Civic SiR both use 1.3mm gaps, looks like the ITR uses 1.1mm probably due to higher compression levels. I wouldn't think the gap difference would trigger a code as I have played with different gaps on the dyno and street and never tripped any codes regardless of how drastic the change was.
Old May 17, 2002 | 09:54 AM
slackeR1366's Avatar
I'm kinda having the same problem, i've been throwing the same codes recently (71,72) but still haven't figured it out.
First I was getting code 72, changed the plugs, wires, cap and rotor at only 17k miles and everything was fine, for at least a day.
Now i'm getting code 71. I can't figure this out, This is driving me crazy.
I took it to the dealer with the first code and they couldn't figure it out,now i'm going to try another dealer and pray.
If you have any luck with a fix, let me know
Old May 17, 2002 | 09:58 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Hmm, my car misses from time to time on the top end and it never throws a code. Of course it's probably firing but just not igniting well because it's so rich.
spintboy
May 1, 2008 07:30 PM
1sikhatch
Feb 25, 2007 02:51 PM
numotive
Aug 2, 2005 11:47 AM
silvercivicsir
Feb 18, 2002 02:36 AM
