TW: Baller Full race parts STG 3GT kIT,Built block,PNP HEAD,EF TRACTION BAR,MOROSO,MSD,AUTO METER AN
Old Jan 21, 2007 | 07:22 AM
b18sihatch's Avatar
Default TW: Baller Full race parts STG 3GT kIT,Built block,PNP HEAD,EF TRACTION BAR,MOROSO,MSD,AUTO METER AN
NEW GT3582R titanium coated exhaust housing-$1150.00
Full Race prostreet ramhorn manifold w/40mm WG flange- $900.00
NEW Full Race Backdoor intercooler 20x3x11- $650.00
NEW Full Race civic intercooler piping anondized black-$300.00
NEW Full Race Couplers $35.00
NEW Full Race T bolt Clamps $60.00
F40 Tial 40mm wastegate $250.00
Block
B16 DOHC VTEC
GREDDY Extreme timing belt
L.A. Ductile Iron Sleeves
JE 8:1 C/R pistons
JE Total Seal ring set
Crower H beam connecting Rods
Crower 220,000psi connecting rod bolts
Balanced & Rotated Rotation Assembly
Deburr Pistons
OEM bearing Set
Moroso Drag Oil Pan
Moroso oil Pickups
Head
PR3 rebuilt head
VTEC selenoid
Ported & polished
5 angle valve job
tapped for cylinder head temp gauge
Transmission
40k miles on transmission
LS S1 LONG GEARS
OBX HELICAL LSD
OBX lsd bolts have been retorqued to specs before professionally installed
3900.00obo for motor listed above
Fuel System
Walbro 255 lph -$100.00
Palmieri inline fuel filter- $60.00
450cc injectors-sold
Zdyne fuel injector gromits-sold
Custom fuel rail-$100.00
Fuel pressure gauge- $20.00
Aeromotive fuel pressure regulator-$250.00
-6an fuel lines-25.00
Electronics
new Autometer boost gauge- $50.00
new Autometer oil pressure gauge-$40.00
new Autometer water temp gauge-$40.00
new Autometer cylinder head temp gauge-$40.00
new Autometer air/fuel ratio gauge-$40.00
MSD knock alert-$150.00
MSD sci-l ingition system-sold
new MSD 8.5mm plug wires-$50.00
Hks Turbo Timer-$80.00
ACT PROLITE Flywheel-$175.00
new ACT Xtrme Pressure Plate-$150.00
new Clutchmasters stage 3 carbon kevlar full face race disk-$225.00 retails for 370.00
new Clutchmasters Throw out Bearing-$50.00
new ARP Pro Flywheel bolts-$50.00
new ARP Pro Clutch bolts-$50.00
Mount kit
ef b seriesAZ RACE Billet motor mounts-$175.00
ef b series AZ RACE Shift Linkage-$75.00
adjustable Short Shifter-$20.00
Energy Shift Bushings- comes with shift linkage
MISC
ZDYNE SECU GOLD with ecu connections- $500.00
GM 3 BAR Map Sensor-$75.00
Endyne Engine Breather Kit-$150.00
PFI SPEED traction bar for EF-$400.00
OBX-R rear lower tie bar-$45.00
MINT EG RADIATOR-$50.00
MINT ef radiator-$50.00
0k cond FAL radiator fan-$30.00
Custom Sway a way Coilovers race runners
6 point Rollcage-$500.00
NEW Corbeau Racing seats-$300.00
NEW Sparco 4 point racing harness$125.00
stainless steel front brake lines
Grant steering wheel-$80.00
Grant steering hub-$25.00
high beam headlights are piaa
-0 battery positive cable-$75.00
-0 battery Negative cable$75.00
Moroso Battery Box-$50.00
Energy Tie Rod end boots bushings-$20.00
Energy Rack & pinion bushings-$20.00
Old Jan 21, 2007 | 09:19 AM
ivt-t's Avatar
Default Re: TW: Baller Full race parts STG 3GT kIT,Built block,PNP HEAD,EF TRACTION BAR,MOROSO,MSD,AUTO METE
pm'ed
Old Jan 23, 2007 | 05:48 PM
b18sihatch's Avatar
bump
Old Feb 5, 2007 | 05:31 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivt-t &raquo;</TD></TR><TR><TD CLASS="quote">pm'ed</TD></TR></TABLE>
Old Feb 6, 2007 | 07:25 AM
vti2's Avatar
I´m interested on the breader-kit. Please pm me.
jdmctr18
Apr 26, 2012 07:34 AM
Eviltek1989
Jun 29, 2010 03:46 AM
JdmDan
Jan 21, 2009 10:34 AM
