lug nuts for a jdm ITR rims?
I will be installing a ctr 5lug on me civic soon and I will also install ARP extended wheel studs. I will be using the 15" GM ITR rims with extended ARP wheel studs, so what kind of lug nuts should I purchase, besides the kicks and T1R???? Thanks in advance
Could I use the RAYS extended lug nuts on my ARP extended wheel studs??
Modified by jdmB18CT-R at 2:37 PM 1/22/2007
.Could I use the RAYS extended lug nuts on my ARP extended wheel studs??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda »</TD></TR><TR><TD CLASS="quote">you should NOT be using tuner style lugnuts .. i would recomend just putting on stock lugs like i run on my jdm itr's</TD></TR></TABLE>
Most tuner lug nuts and other aftermarket lug nuts have a tapered (conical) seating area. You need OEM lug nuts (or any lug nuts that have a spherical (ball-shaped) seating area).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmB18CT-R »</TD></TR><TR><TD CLASS="quote">
Modified by jdmB18CT-R at 2:37 PM 1/22/2007</TD></TR></TABLE>
The same replies from before still apply in this case.
