D16A9 Tranny L3 question
Old Jan 20, 2007 | 03:49 PM
Mcapela's Avatar
Default D16A9 Tranny L3 question
Hi guys
i have a crx 1.6 16V ED9 type with engine D16A9 dohc non vtec , i think this engine in USA is the ZC but not sure,my car is from 89 June.
i wont now buy a better clucth anf flywheel, my tranny is L3, somebody can help me concerning the splines number and clucth dimensions ?
where i live, honda portugal can not help me.
thanks and regards
Old Jan 20, 2007 | 03:59 PM
CRX1.4DualCarb's Avatar
Default Re: D16A9 Tranny L3 question (Mcapela)
Hi there. Yes it is the dualcam ZC.
As for the flywheel/clutch I think it will fit any that is for a D engine..
Is this right H-T people?
Old Jan 20, 2007 | 04:15 PM
Mcapela's Avatar
Default Re: D16A9 Tranny L3 question (CRX1.4DualCarb)
Hello, / Ola, tudo bem?
i think depending of thje years the clutches size and splines number are different, but not sure,
thanks/obrigado companheiro
Old Jan 20, 2007 | 04:41 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mcapela &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys
i wont now buy a better clucth anf flywheel, my tranny is L3, somebody can help me concerning the splines number and clucth dimensions ?</TD></TR></TABLE>
It depends on the year of your transmission. '88 L3 transmissions had a 21-spline input shaft, while '89-91 L3 transmissions had a 20-spline input shaft - at least, this is true for cars in the US. You need the clutch that matches the year of your transmission.
Since your car was built in June '89, you should have the 20-spline input shaft (provided that the transmission is original).
Regarding clutch diameter, '88-89 clutch discs were 200mm in diameter, while '90-91 clutch discs were 212mm in diameter. You can use a '90-91 clutch on an '89 car, but you must use the '90-91 flywheel along with it.
yaaj1320
Feb 9, 2007 08:34 PM
srv3fender
Apr 13, 2005 09:47 AM
johnpowellcrx
Oct 5, 2004 09:23 PM
giantdumbass
10
Oct 18, 2003 11:53 AM
