need more power any suggestions?
Old Jan 20, 2007 | 03:33 PM
95bkeg's Avatar
Default need more power any suggestions?
I have a 95 ex coupe w/D16Z6 (70,000 miles). The engines internals are all stock but I have the following done to it: DC (4-2-1) header, 2.5 inch mandrel bend ehxaust w/Skunk 2 muffler, AEM short ram intake, Skunk 2 66mm throttle body, Skunk 2 intake manifold, MSD 6AL ignition, race plug wires and V-power plugs, it has a Apxi V-AFC II and has been tuned to 110 whp but since then I took off the AC, power stearing and stripping the trunk dropping about 70 lbs. So now I would think the car is more like 116 whp. I always use 93 octain gas and do regular oil changes with synthetic oil. Basicaly I have just made the car breath better and in the future when I get it ported and polished with a new Skunk 2 top end it will respond better. But are their anyother things other then dropping more weight or forced induction (including spray) I can do to givve me more puwer. I have heard of others putting in bigger injectors or putting a fuel pressure regulator in for increased fuel but without more air (they both had N/A cars) I don't really think it would do much. Any help would great
Old Jan 20, 2007 | 03:50 PM
95bkeg's Avatar
Default Re: need more power any suggestions? (95bkeg)
bump
Old Jan 20, 2007 | 03:54 PM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95bkeg &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 ex coupe w/D16Z6 (70,000 miles). The engines internals are all stock but I have the following done to it: DC (4-2-1) header, 2.5 inch mandrel bend ehxaust w/Skunk 2 muffler, AEM short ram intake, Skunk 2 66mm throttle body, Skunk 2 intake manifold, MSD 6AL ignition, race plug wires and V-power plugs, it has a Apxi V-AFC II and has been tuned to 110 whp but since then I took off the AC, power stearing and stripping the trunk dropping about 70 lbs. So now I would think the car is more like 116 whp. I always use 93 octain gas and do regular oil changes with synthetic oil. Basicaly I have just made the car breath better and in the future when I get it ported and polished with a new Skunk 2 top end it will respond better. But are their anyother things other then dropping more weight or forced induction (including spray) I can do to givve me more puwer. I have heard of others putting in bigger injectors or putting a fuel pressure regulator in for increased fuel but without more air (they both had N/A c$ars) I don't really think it would do much. Any help would great </TD></TR></TABLE>
sell all of the above. and save for at least a b-series.
or
go to APC's web site and buy a shift ****.
Old Jan 20, 2007 | 04:10 PM
95bkeg's Avatar
I will be doing a big build in the future but want to do a smaller one to start off on so I have some experiance before I tackle a build on a 1.8 with pretty much every thing done to it thats out there on the market (after I get out of college and start making some real money) so thats why I want to do a small scale build on the D-series.
Old Jan 20, 2007 | 04:15 PM
doood's Avatar
been there done that
you've got all the bolt on's covered. do a cam and pistons. fuel components wont do anything for you except giving you a lighter wallet.
short of boost, you wont get big hp gains from anything else.
gmctruck68
Apr 24, 2008 11:56 AM
95bkeg
Jan 20, 2007 04:08 PM
bigz187
Mar 19, 2006 06:28 PM
Chris_Bye
Sep 3, 2004 11:13 AM
Chris_Bye
Jul 4, 2004 12:56 AM
