GSR Crx need help asap.
Old Jan 20, 2007 | 01:42 PM
EJgsr's Avatar
Default GSR Crx need help asap.
ok heres what we did.
91 crx hf
obd1 GSR
obd0 to obd1 jumper
we have codes 6 and 10 (intake air temp and water temp)
continuity from the ECU to the plugs
and a rev limiter at 3500
runs perfect till 3500
what the hell can it be.
tried every thing we could think of and still cant get it to not throw codes.
help asap thanks.
Modified by USDMej1 at 11:41 AM 1/21/2007
Old Jan 20, 2007 | 03:50 PM
EJgsr's Avatar
Default Re: GSR Crx need help asap. (USDMej1)
well thanks for all the help
Old Jan 20, 2007 | 04:15 PM
gsxr1k05's Avatar
are the sensors wires up right, are there shorts in the wire? could the sensors be bad?
Old Jan 20, 2007 | 04:18 PM
EJgsr's Avatar
Default Re: GSR Crx need help asap. (gsxr1k05)
i'm thinking too, sensors are bad. thanks
Old Jan 20, 2007 | 04:19 PM
B18civic5g's Avatar
find some one that knows what there doing!!!!!!!!!!!!!!!!!!!
Old Jan 21, 2007 | 10:40 AM
EJgsr's Avatar
Default Re: GSR Crx need help asap. (B18civic5g)
no help?
Old Jan 21, 2007 | 10:58 AM
HondaPartsHero's Avatar
Technical Hero
Old Jan 21, 2007 | 02:02 PM
EJgsr's Avatar
Default Re: GSR Crx need help asap. (HondaPartsHero)
thanks you so much. your the man.
Old Jan 21, 2007 | 05:11 PM
Technical Hero
check and make sure you don't have the TPS and MAP sensor backwards. I don't think either of those codes you have would cause this to stop at 3500RPMS.
Old Jan 21, 2007 | 05:26 PM
oodie's Avatar
Yea those two codes should not put you in limp mode check plugs reset ecu and try again
Old Jan 21, 2007 | 06:12 PM
EJgsr's Avatar
Default Re: GSR Crx need help asap. (oodie)
will a bad dizzy set it limp mode.?
Old Jan 22, 2007 | 04:49 AM
B18civic5g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">check and make sure you don't have the TPS and MAP sensor backwards. I don't think either of those codes you have would cause this to stop at 3500RPMS.</TD></TR></TABLE>
I dont think they can be backwards cause, the map sensor is not on the engine harrness, it comes out of the body harrness. so its hard to get those backwards.
Old Jan 22, 2007 | 05:56 AM
HT Chaplain's Avatar
Loved
what ECU are you using?
Old Jan 22, 2007 | 06:11 AM
FaceTuned's Avatar
the dizzy can cause that problem.
Old Jan 22, 2007 | 07:41 AM
Mr. Giggles's Avatar
Default Re: GSR Crx need help asap. (HT Chaplain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">what ECU are you using?</TD></TR></TABLE>
P72
Old Jan 22, 2007 | 07:39 PM
MHSD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">thanks you so much. your the man. </TD></TR></TABLE>
no brian you are the man you are so cool......
Old Jan 23, 2007 | 04:56 PM
Default Re: GSR Crx need help asap. (LONGLIVETHEEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LONGLIVETHEEF &raquo;</TD></TR><TR><TD CLASS="quote">
no brian you are the man you are so cool...... </TD></TR></TABLE>
actually mike you are the man.
Old Jan 30, 2007 | 02:11 PM
B18civic5g's Avatar
Default Re: GSR Crx need help asap. (SmrCRX)
bump for help
Old Jan 30, 2007 | 04:49 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">will a bad dizzy set it limp mode.?</TD></TR></TABLE>
yes.
Old Jan 30, 2007 | 06:35 PM
Tippyman's Avatar
Default Re: GSR Crx need help asap. (STREETWERKZ)
yes. </TD></TR></TABLE>
Trust me, it will. Lol, running on the highway on a D15B1 running on 3 cylinders in limp mode is not fun.
d16z6EG
Dec 8, 2010 02:44 PM
peacexisxfree
Nov 23, 2008 09:08 PM
jdmef4door
Feb 28, 2007 05:43 AM
lsturborex
Dec 22, 2003 07:35 AM
comptechgsr
May 9, 2002 01:52 PM
