will a 0 offset wheel fit a 95 accord??
Old Jan 20, 2007 | 01:16 PM
hb_guy's Avatar
Default will a 0 offset wheel fit a 95 accord??
just as the topic says. it is a 15x8 wheel with a 0 offset and i just want to know if it would fit and what size tires go with it.. thanks
BTW stock ex rims are 15x6 with 195-60-15. not sure on the offset
Old Jan 20, 2007 | 03:44 PM
vtecsi00's Avatar
Default Re: will a 0 offset wheel fit a 95 accord?? (hb_guy)
no it will not fit.. it will stick out past the fender quite a bit and rub like crazy.. you need a 35 to 45mm offset
Old Jan 20, 2007 | 06:24 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: will a 0 offset wheel fit a 95 accord?? (vtecsi00)
If this is for street use, 15x8 is too wide for the proper sized tires for your car. Depending on which engine, body style, and version '95 Accord you have, the best tire size is either 195/60-15 or 205/60-15. 195/60-15 is usually approved only for mounting on rims 5.5-7.0 inches wide, and 205/60-15 for rims 5.5-7.5 inches wide. Your stock size 15x6 rims are perfect for both sizes.
If this is for competition tires for track/autocross/dragstrip use, check the tire manufacturer's specs for range of approved rim widths for the size tire you're considering using.
Old Jan 20, 2007 | 07:01 PM
hb_guy's Avatar
Default Re: will a 0 offset wheel fit a 95 accord?? (nsxtasy)
thanks for the info. i just came across these wheels that looked good and i had to know.. thanks
Old Mar 1, 2007 | 03:16 PM
boosteddagsr's Avatar
they will fit with some rolling of the fenders
j_mee_5
Jan 30, 2010 02:01 PM
bsivoljr
Jul 11, 2007 01:16 PM
BuyImports2
Mar 19, 2005 04:35 PM
2000Accord5sp
Oct 25, 2002 05:04 AM
2ndgen-e
Jul 24, 2001 11:05 AM
