Ignition output signal?
Old Jan 20, 2007 | 11:24 AM
gwchndlr's Avatar
Default Ignition output signal?
i checked the ecu codes on my gf's 1994 accord 4dr lx. i got code 15 which is Ignition output signal...what does that mean? ive searched a bit and the most popular answer ive found is that i should replace the distributor. i just want to confirm that. any help would be appreciated. thanks.
Old Jan 20, 2007 | 01:55 PM
gwchndlr's Avatar
Default Re: Ignition output signal? (gwchndlr)
please help!! i dont want to drop ~$200 on a dizzy and find out it was the igniter or something else.
Old Jan 21, 2007 | 09:43 AM
momstaxi's Avatar
i would just try the ignition control module. thats what is the problem most of the time. if you have a book, it gives you a test procedure for testing the icm inside of the distributor
Old Jan 21, 2007 | 01:28 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gwchndlr &raquo;</TD></TR><TR><TD CLASS="quote">i checked the ecu codes on my gf's 1994 accord 4dr lx. i got code 15 which is Ignition output signal...what does that mean? ive searched a bit and the most popular answer ive found is that i should replace the distributor. i just want to confirm that. any help would be appreciated. thanks. </TD></TR></TABLE>
Does the code come back after you clear it?
fletcher85
Nov 25, 2014 07:35 PM
slel_Lee
Apr 29, 2013 06:59 PM
carproblems
Apr 17, 2008 02:49 PM
ohiojack
Nov 4, 2007 04:40 PM
CiViC SiR
Jun 26, 2003 07:07 AM
