obd-o tps and throttle body
Old Jan 20, 2007 | 11:13 AM
Mr_Si-R's Avatar
Default obd-o tps and throttle body
i have a crx with an si head and a MPFI<---i think thats right-swap oh hell i have an intake manifold like an Si. ive have had a code for the tps for a while now, but not its causing my car to jerk really bad until my CEL comes on. now my question is can i use the whole throttle body from an 86 integra of should i just take the tps of if it? the guy at the junk yard said he would sell me the whole throttle body for $35, which isnt bad, but i only really need the tps.
questions
1)can i use the tps from an 86 integra?
2)can i use the whole throttle body from an 86 integra?
thank you for your time
Old Jan 20, 2007 | 11:26 AM
crxnj's Avatar
Default Re: obd-o tps and throttle body (Mr_Si-R)
ive put an 88 integra throttlebody and tps on a d16a6 intake before,,,Not sure if the 86 integra is different, i know they have the same d16a1 engine though.
Old Jan 20, 2007 | 11:28 AM
Mr_Si-R's Avatar
Default Re: obd-o tps and throttle body (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">ive put an 88 integra throttlebody and tps on a d16a6 intake before,,,Not sure if the 86 integra is different, i know they have the same d16a1 engine though.</TD></TR></TABLE>
it should be the same right, because its obd-0?
Old Jan 20, 2007 | 11:31 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Si-R &raquo;</TD></TR><TR><TD CLASS="quote">
it should be the same right, because its obd-0?</TD></TR></TABLE>
Its the same d16a1 engine,,but i know the 86-87 had some little differences..im sure you could look up the part number and see if its the same for 87 to 88..
Old Jan 20, 2007 | 11:49 AM
Mr_Si-R's Avatar
questions
thank you for your time</TD></TR></TABLE>
bump?
Old Jan 20, 2007 | 12:20 PM
oodie's Avatar
As far as i know there are no differences between tps with years of car so it should work
confutatis
May 15, 2006 05:06 PM
tigueremalo
Mar 28, 2006 06:29 PM
vegaskurt
Feb 10, 2005 06:15 PM
jdmcivicferio
Feb 3, 2004 09:49 AM
