Quality HID KIts
Old Jan 20, 2007 | 10:44 AM
skingfreak's Avatar
Default Quality HID KIts
Im looking for a quality HID kit. I was looking on ebay and came accross a brand called MTEC and it seems to be pretty nice. everything is made in japan instead of china or korea.
Any thoughts? or sugestions on what i should get? i need H1 bulb size and 5000-6000K color temperture.
THere going in a new set of TYC projector housings. Just installed them and they look mean
Old Jan 20, 2007 | 12:02 PM
skingfreak's Avatar
Default Re: Quality HID KIts (skingfreak)
or would any ebay kit suite my needs. and i cant goto a local shop to get it seeing as there arent any in my area
Old Jan 20, 2007 | 12:50 PM
gianinline's Avatar
Just for your knowledge. The HID kit from korea or China, isn't necessarly a "bad product" because it won't last, it's because the cost of labor is incredibly low.
There are lots of things that get done in China, and only get stamped and "ticketed" at another country.... and it will never say..."made in china".
Old Jan 20, 2007 | 01:30 PM
skingfreak's Avatar
Default Re: (gianinline)
no i know that, china can and does make SOME quality items. So at what price mark are you most likely going to get a quality item? that is the guessing game.
Old Jan 20, 2007 | 02:26 PM
gianinline's Avatar
I would say... from 180 to 350......
Less than that... could be a low quality product.... unless it has warranty and stuff...
Old Jan 20, 2007 | 06:10 PM
SuShiBoiiii's Avatar
find some phillips ones or catz
Old Jan 20, 2007 | 09:23 PM
skingfreak's Avatar
Default Re: (SuShiBoiiii)
phillips would be good, but there are crazy expensive. there like $450...atleast the ones i have found
Old Jan 20, 2007 | 10:24 PM
Bruce Banner's Avatar
Default Re: (skingfreak)
I have Denso, works fine.
Old Jan 21, 2007 | 05:43 AM
skingfreak's Avatar
Default Re: (Bruce Banner)
how much was it? did you get it off of ebay?
Old Jan 21, 2007 | 08:03 AM
skingfreak's Avatar
how long have you had it?
Old Jan 21, 2007 | 08:58 AM
ebay, 2 yrs now
Old Jan 21, 2007 | 09:13 AM
skingfreak's Avatar
cool, what type of housing are you using?
Also does anyone know if it maters if the ignitors are built into the ballasts or if there stand alone?
i was looking at these http://www.cqlight.ca/product_...69da9
Old Jan 21, 2007 | 09:29 AM
oem housing.
Stick to a plug and play kit, philips, etc.
Old Jan 21, 2007 | 09:46 AM
skingfreak's Avatar
well i just bought some TYC projector housings and they were plug and play with an adaptor. so if i bought an H1 kit for those, use my adaptor will it still be plug and play?
Old Jan 21, 2007 | 12:19 PM
AFAccord's Avatar
https://honda-tech.com/zerothread?id=1801734
Search...
Old Jan 21, 2007 | 12:32 PM
Default Re: (AFAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1801734
Search...</TD></TR></TABLE>
he's on that thread already.
Old Jan 21, 2007 | 12:53 PM
skingfreak's Avatar
how are your bulbs working now? any problems? actuly i was looking for that thread the other day. thanks!
Old Jan 21, 2007 | 04:18 PM
i'm on philips bulbs.
Old Jan 21, 2007 | 06:34 PM
skingfreak's Avatar
did your first ones mess up? or just decide to go with name brand bulbs?
Old Jan 21, 2007 | 06:41 PM
AFAccord's Avatar
I plan on tryin to get some new pictures, but it's raining right now. Gonna try to set up the shots so they look more believeable. ISO at 1600 or 3200, contrast all the way down, and I'll try to get some other lighting in there for comparison. Everything in my setup is doin just fine.
Old Jan 21, 2007 | 06:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak &raquo;</TD></TR><TR><TD CLASS="quote">did your first ones mess up? or just decide to go with name brand bulbs?</TD></TR></TABLE>
It came with Philips bulbs
Old Jan 21, 2007 | 07:30 PM
gianinline's Avatar
I'm sorry for making questions on someone's thread... but...
CAN SOMEONE PLEASE FIND ME LINK TO A PLACE WHERE I CAN GET "H4 HID 6000K" BULBS, WITHOUT ANY WIRING.. I JUST NEED THE BULBS AND THAT'S IT.... I'VE BEEN SEARCHING ON EBAY AND ON THE WEB IN GENERAL, "HIDWORLD" SUCKED... SO... WHERE COULD I GO GET SOME?!
THANKS FOR ANY REPLIES TO THIS POST.
Old Jan 21, 2007 | 07:35 PM
AFAccord's Avatar
Calm down dude!! lol I'm gonna say with 99.9998% certainty that you simply won't find an H4 HID bulb with just terminals, no wire. It's just completely impractical for anyone to manufacture that.
Old Jan 22, 2007 | 02:50 AM
skingfreak's Avatar
would you guys recomend 5000K or 6000K i know 5K is brighter, but 6000K has a nice white look. im somewhat leaning for the 6K since its the compramise between color and light output.
Hey AFAccord, how do you adjust the height of the low beams on your headlights? is it just the inner long screws on our housings?
Reason i ask is the right one is pointed slightly higher than the left, and there both pointed a little higher than they should, which doesnt bother me except im trying to be nice for other drivers.
Old Jan 22, 2007 | 02:54 AM
AFAccord's Avatar
When you take off the cap behind the low beam projectors, there are two phillips head screws on opposite corners. One adjusts vertically, the other, horizontally.
I'd prefer 5000K since it's closer to true daylight color. Let the cutoff shields do the color work.
