oem foglights wired to turn on only when headlights are on? changeable?
Hi! I just recently had the dealer install my OEM foglights and it only turns on when the headlights are on low beam. Does anyone know which wires to switch out if I want to wire the switch to the DRLs. That way I still have control of the fogs from the switch but are able to turn it on and off as long as the DRLs are on. Thanks!
I wired mine so that the fogs can be on whenever... including when the brights are on which is actually illegal. anyway its as simple as leaving one pin out of the connector under the dash. i'll see if i can post a picture of which wire it is. draw backs are: little foglight emblem doesnt light up on your cluster and you can potentially leave the foglights on over night or something and drain the battery
goldenmustache
Sep 30, 2009 06:59 AM
OH honda boy
Honda Civic (2001 - 2005)
Sep 28, 2009 07:28 AM
db1st
Lighting
Mar 4, 2008 10:10 PM
litterbox
10
Jan 20, 2005 03:53 PM
