will these axles work?
Old Jan 20, 2007 | 08:39 AM
classciv's Avatar
Default will these axles work?
i have an engine and tranny out of a 91 crx si, i am thinking about getting a 88 hf with a blown motor, what axles will work with my engine and tranny because i though i rememberd that the hf/std axles would not work in a si,dx,or lx. am i right?
Old Jan 20, 2007 | 09:01 AM
dr_latino999's Avatar
Default Re: will these axles work? (classciv)
All USDM Civic / CRX axles are the same at the transmission, so it only matters what your exterior hubs are. So in the HF you could use your stock HF axles until you swap up to some beefier wheel hubs.
Old Jan 20, 2007 | 09:12 AM
[JL_Audio]
Guest
Posts: n/a
Default Re: will these axles work? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">All USDM Civic / CRX axles are the same at the transmission, so it only matters what your exterior hubs are. So in the HF you could use your stock HF axles until you swap up to some beefier wheel hubs.</TD></TR></TABLE>
Old Jan 23, 2007 | 08:17 PM
[JL_Audio]
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [JL_Audio &raquo;</TD></TR><TR><TD CLASS="quote">]</TD></TR></TABLE>
firejackal
Jul 12, 2012 10:11 AM
tyvtec23
Mar 6, 2012 08:48 AM
SnakeBait
Jun 13, 2007 10:20 PM
superbeastcrx
Oct 28, 2004 10:44 AM
whizdumb
Apr 11, 2003 07:56 PM
